Re: Can you re-sleeve a sleeved cylinder?
[Re: Cab_Burge]
#2361867
08/29/17 07:09 PM
08/29/17 07:09 PM
Posts: 1,505 TN
SCATPACK 1
TN
Absolutely Make sure and take the block to a good Hi Po machine shop, not your local automotive rebuilder shop You might want to think about buying ductile iron sleeves also instead of your every day cheap rebuilder sleeves Not cheap but they are way better than standard rebuilder sleeves, after all it is a hemi, correct Cab Have you ever ran a block with all 8 bores sleeved? Any issues?
Old Geezer Racing
[Re: SCATPACK 1]
#2361871
08/29/17 07:18 PM
08/29/17 07:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Absolutely Make sure and take the block to a good Hi Po machine shop, not your local automotive rebuilder shop You might want to think about buying ductile iron sleeves also instead of your every day cheap rebuilder sleeves Not cheap but they are way better than standard rebuilder sleeves, after all it is a hemi, correct Cab Have you ever ran a block with all 8 bores sleeved? Any issues? You are better off IF all of them are bored or done at one time.. I've had the same cyl done twice(broke) on my R3 block.. that way the block distortion is minimal
[Re: 73DAD]
#2362205
08/30/17 10:26 AM
08/30/17 10:26 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Like said already, no problem resleeving a cylinder that's already been sleeved...typically. The type of shop that does it doesn't matter as long as the machinist knows what he's doing.
[Re: 73DAD]
#2362304
08/30/17 01:32 PM
08/30/17 01:32 PM
Posts: 4,457 Washington
madscientist
Washington
Thanks for the responses guys. Next problem is going to be if there is enough deck left to true up the sleeves and get rid of the o-rings(fire-rings?). Unless someone has already decked the crap out of it, the grooves should only be about .035 deep. They should machine out easily. As someone already mentioned, use a high quality, ductile iron sleeve. They cost more but they are much better. I can't recall how many blocks I've re-sleeved every hole on. If you work on big forklifts and other equipment like that, it's normal to sleeve the block several times.
