Big Power, Small Tire
#2360376
08/26/17 11:42 PM
08/26/17 11:42 PM
Posts: 326 Alberta
Wookie316
Alberta
I've been running the Hoosier C07 10.5x30 Radial Slick. It hooks well on my car, but since Barney now has 100 + HP more they fade away very quick. Wondering what guys are using. Love the top end stability of a radial on a big car, but I may have no choice and have to go back to a Bias slick. Those running more than 800 HP on a 10.5 I need opinions. I can keep running these, but looking for something with a bit more life. Yes I'm conservative on the burnout if anyone is wondering. Thanks.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Big Power, Small Tire
[Re: Wookie316]
#2360381
08/26/17 11:51 PM
08/26/17 11:51 PM
Posts: 2,490 Sydney,Australia
tex013
Sydney,Australia
Wookie, Look at the MT Pro bracket radial . 29.5x10.5R15 . Its 30" tall
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Wookie316]
#2360389
08/27/17 12:12 AM
08/27/17 12:12 AM
Posts: 1,481 Outside
thedriver
Outside
Are you writing posts on the return road? Lol
1973 challenger Dana. 4 speed. Low deck.
[Re: mercman1]
#2360420
08/27/17 01:21 AM
08/27/17 01:21 AM
Posts: 326 Alberta
Wookie316
Alberta
"Wookie, Look at the MT Pro bracket radial . 29.5x10.5R15 . Its 30" tall"
So far I've gone 9.20s at over 3500lbs in a 69 GTX on the above mention tire. All motor 540 Hemi. needs VERY little burn out. Not quite. Back at hotel. I went from 5 passes within .04 last night to only hooking 2 times in 7 passes today. Test and tunes. Gotta love them.
[Re: Wookie316]
#2361037
08/28/17 10:34 AM
08/28/17 10:34 AM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
I use M/T 29.5x10.5 stiff sidewall ET Drag slicks w/ tubes when the track won't work w/ radials.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: Wookie316]
#2361050
08/28/17 11:08 AM
08/28/17 11:08 AM
Posts: 326 Alberta
Wookie316
Alberta
I know it was somewhat a prep issue because all the big power small tire guys were having trouble. That said, I do need new tires regardless.
[Re: Wookie316]
#2361142
08/28/17 01:55 PM
08/28/17 01:55 PM
Posts: 19,537 Las Vegas
Al_Alguire
Las Vegas
We do ok on a 29.5x10.5 SS M/T. We have well north of 800HP NA. We have been 1.13 60' and 8.04 so far this year..
[Re: Wookie316]
#2361145
08/28/17 01:59 PM
08/28/17 01:59 PM
Posts: 326 Alberta
Wookie316
Alberta
Pulled trigger on a set of M/T PBR's. $60 a tire cheaper than the Hoosiers I was running. I can get used to that.
[Re: Wookie316]
#2361219
08/28/17 04:57 PM
08/28/17 04:57 PM
Posts: 52 canada
W2-408
canada
You're going to love the PBR's. At Castrol I don't even use the line lock anymore. Just stab the throttle out of the burnout box, never had them spin yet and the 60 foot doesn't move more than about 8 thou all day. My car runs pretty much the same ET's as you.
Street car, 10.12 @ 132 with W2's and pump gas
[Re: Wookie316]
#2361224
08/28/17 05:09 PM
08/28/17 05:09 PM
Posts: 326 Alberta
Wookie316
Alberta
Great to know. Thanks. I like that they are cheaper too. How many passes you getting on a set?
[Re: Wookie316]
#2361228
08/28/17 05:20 PM
08/28/17 05:20 PM
Posts: 52 canada
W2-408
canada
I just switched to them this year, with basically no burn out on them over close to 100 passes so far they look like new. I know of people in the states that say they're getting close to 300 passes on a set.
[Re: Wookie316]
#2361248
08/28/17 05:58 PM
08/28/17 05:58 PM
Posts: 326 Alberta
Wookie316
Alberta
I'll be very happy if I can get 100+ on a set. Thanks for the info. Much appreciated.
[Re: Wookie316]
#2361300
08/28/17 07:30 PM
08/28/17 07:30 PM
tex013
Sydney,Australia
Wookie , I went just over 150 passes before swapping out mine . There was still more left but was too close to end of season rounds to risk
Tex
[Re: Wookie316]
#2361328
08/28/17 08:11 PM
08/28/17 08:11 PM
Posts: 326 Alberta
Wookie316
Alberta
I hope to see that # out of mine however it has been suggested to me that big power in a big car like mine may not like the sidewall punishment the receive and shorten the life of an average user.
[Re: Wookie316]
#2368572
09/10/17 11:48 PM
09/10/17 11:48 PM
Posts: 326 Alberta
Wookie316
Alberta
Ran the PBR's this weekend. 60 is same as Hoosiers. Had to run 18 PSI to hook. Hoosier's work at 20. Lower PSI = lower MPH & ET. That was at SIR. Need to try at Castrol yet.
[Re: Wookie316]
#2368597
09/11/17 12:37 AM
09/11/17 12:37 AM
tex013
Sydney,Australia
Wookie , I am at 16 1/4psi thereabouts . Didn't like the 18 1/2 I used in the Hoosier radial
Tex
[Re: Cab_Burge]
#2368648
09/11/17 03:35 AM
09/11/17 03:35 AM
tex013
Sydney,Australia
Cab isn't that the truth Tex
