Re: Lower contol arm bushings
[Re: cudaman1969]
#2362287
08/30/17 01:00 PM
08/30/17 01:00 PM
Posts: 4,454 Morristown Tn.
71birdJ68
Morristown Tn.
No, it will just rip the rubber loose when you let it down on the ground. Or, are you joking?
[Re: 71birdJ68]
#2362295
08/30/17 01:18 PM
08/30/17 01:18 PM
Posts: 8,273 fredericksburg,va
cudaman1969
fredericksburg,va
No, it will just rip the rubber loose when you let it down on the ground. Or, are you joking? Just joking, but, if you tighten the nut at rest, what heppens when you raise the car on a lift? Does it "rip" the rubber then. Sounds like bs to me. Haeven help if the wheel falls in a hole or the front end bottoms out ( like in normal use) your rubbers rip.
[Re: 71birdJ68]
#2362311
08/30/17 01:40 PM
08/30/17 01:40 PM
cudaman1969
fredericksburg,va
Then it only goes half travel, but if tightened on the lift, it will go more than full travel when moving in it arc. Wouldn't any travel twist that rubber?
[Re: cudaman1969]
#2362358
08/30/17 03:15 PM
08/30/17 03:15 PM
71birdJ68
Morristown Tn.
Twisting is normal, that is the design, but when you exceed the twist limit it rips it loose from the metal it is anchored to.
[Re: cudaman1969]
#2362360
08/30/17 03:23 PM
08/30/17 03:23 PM
dogdays
I can't believe you are arguing about this. When nut is tightened at ride height, when fully compressed or fully ewxtended, the bushing is twisted halfway. The designers made the bushing for this use. When you tighten the nuts with wheels dangling, when at level the busthing is already at its limit in one direction. Then when the wheel is pushed farther up, the bushing is past its workable range.
Also, it doesn't just rip or twist out immediately, it takes some time and number of cycles. But the service life of a rubber bushing misinstalled in this fashion will be compromised severely, like total failure in 1/10 the normal life.
Several years ago I got a ride in an A-body that had all poly bushings installed. It felt sharp. steering turn-in was immediate. I asked the owner his opinion of the bushings and he said he loved them for the reason I'd just noted, but in his opinion they transmitted more shock to lower ball joints, which caused the ball joints to wear more quickly.
Back in the day, a trick to stiffen factory rubber bushings was to drive small nails into the rubber. I remember this in a car magazine around 1975.
R.
[Re: 11secaarcuda]
#2362468
08/30/17 06:52 PM
08/30/17 06:52 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
What steel pin?
It's adhered to the inner sleeve, which is bolted to the pivot pin.
[Re: 11secaarcuda]
#2362543
08/30/17 09:51 PM
08/30/17 09:51 PM
Supercuda
About to go away
About to go away
up yours
Do you think it's attached to that pin?
I already explained how it attached.
[Re: Supercuda]
#2362550
08/30/17 10:07 PM
08/30/17 10:07 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Looks to me like he just answered the question, "What steel pin?".
I have mechanical Aptitude. I can screw up anything.
[Re: krautrock]
#2362558
08/30/17 10:17 PM
08/30/17 10:17 PM
Posts: 8,142 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
supposed to do final torque on the LCA bushings while the car is at ride height. it's probably fine to snug the LCA nuts down so it pulls the arm into the kmember but no further than just snug. same with the strut rod bushings and the upper control arm bushings.
i believe the ball joints and tie rod stuff is fine to torque down whenever... FSM mentioned the shock bolts too, don't recall a mention of the upper control arm but it makes sense and after the alignment loosen/tighten I'd think that would be good
[Re: cudaman1969]
#2362568
08/30/17 10:24 PM
08/30/17 10:24 PM
Posts: 18,157 Mass
DAYCLONA
Mass
So,..if tightened while on the lift, that would make it easier to do wheelies on a race car then.?! ...Already winter on Moparts?
[Re: UCUDANT]
#2362643
08/31/17 12:31 AM
08/31/17 12:31 AM
Posts: 4,730 Florida
BDW
Hers's a comparison for ya.
DON'T mess with AC Delco non concentric
I took these photo's myself in my garage of parts I orderded.
Measure your Moog upper control bushings is all I wll say...... been there The AC parts look better to me?' The offset bushings are supposed to be offset? Am I missing something
[Re: DAYCLONA]
#2362912
08/31/17 04:16 PM
08/31/17 04:16 PM
cudaman1969
fredericksburg,va
So,..if tightened while on the lift, that would make it easier to do wheelies on a race car then.?! ...Already winter on Moparts? Cool, just trying to make people question instead of just taking for granted.
