8 3/4 axles in a narrowed Dana 60 truck housing
#2360322
08/26/17 09:36 PM
08/26/17 09:36 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Any one ever made their own 60 from a truck axle and used stock b body 8 3/4 length axles?
Axles are 30 spline after market. I'd rather use an off the shelf axle as opposed to custom.
I could buy new aftermarket stock length dana 60 axles but I'm not sure there is one that's fits my 65 b body.
I ask this as I understand the dana used different length shafts than the 8 3/4.
When I set this all up, truck housing, 30 spline power loc, dr diff ends and bearings and my 8 3/4 shafts I hadn't thought about the dana having different shaft length/off set.
Re: 8 3/4 axles in a narrowed Dana 60 truck housing
[Re: B5 Bee]
#2360337
08/26/17 10:10 PM
08/26/17 10:10 PM
Posts: 4,673 Wichita
GY3
Wichita
The aftermarket axles from Dr. Diff are dirt cheap and come with bearings and flanges. Don't bother getting the screw in studs from him, however. Everything else was good including the spool.
The small extra that the axles cost are worth it.
[Re: B5 Bee]
#2360339
08/26/17 10:14 PM
08/26/17 10:14 PM
Posts: 1,807 North Dakota
Azzkikrcuda
North Dakota
Had a E-body 8-3/4, cut the housing ends off it and welded the ends to the truck housing and used the axles from it in the a truck housing. Pinion ends up slightly off center, But it has no issues with vibration. Would do it again, only cost was the truck housing $100 and time.
The only Carbs I care about are under the hood!
[Re: NTOLERANCE]
#2360349
08/26/17 10:33 PM
08/26/17 10:33 PM
Posts: 8,265 fredericksburg,va
cudaman1969
fredericksburg,va
Just center the housing and use the 8-3/4 axels, done. Every housing I ever cut down was centered, NEVER a problem. Depending on the tires (slicks), will be how long the 8-3/4 axels last, street car, do it. Only problem with Dana, limited gear choice, no 2.76 ratio.
[Re: cudaman1969]
#2360403
08/27/17 12:44 AM
08/27/17 12:44 AM
Posts: 43,176 Bend,OR USA
Cab_Burge
Just center the housing and use the 8-3/4 axels, done. Every housing I ever cut down was centered, NEVER a problem. Depending on the tires (slicks), will be how long the 8-3/4 axels last, street car, do it. Only problem with Dana, limited gear choice, no 2.76 ratio. Who would really want a 2.76 ratio in a Dana 60 when the 3.0? ratio is available in the Dana 61
[Re: Cab_Burge]
#2360438
08/27/17 02:06 AM
08/27/17 02:06 AM
cudaman1969
fredericksburg,va
Just center the housing and use the 8-3/4 axels, done. Every housing I ever cut down was centered, NEVER a problem. Depending on the tires (slicks), will be how long the 8-3/4 axels last, street car, do it. Only problem with Dana, limited gear choice, no 2.76 ratio. Who would really want a 2.76 ratio in a Dana 60 when the 3.0? ratio is available in the Dana 61 For a Dana "60" it's 3.54. If you like spinning around at 3000 rpm all the time go for it. I'm hoping my 29.5 tires will tone my 3.54 down a little. If to low then the 4.10s. Depends on your driving pleasures.
[Re: Cab_Burge]
#2360444
08/27/17 02:20 AM
08/27/17 02:20 AM
moparpollack
Lil Herman
Lil Herman
85086
Just center the housing and use the 8-3/4 axels, done. Every housing I ever cut down was centered, NEVER a problem. Depending on the tires (slicks), will be how long the 8-3/4 axels last, street car, do it. Only problem with Dana, limited gear choice, no 2.76 ratio. Who would really want a 2.76 ratio in a Dana 60 when the 3.0? ratio is available in the Dana 61 A turbo car would like the 3:00 gear.
[Re: moparpollack]
#2360457
08/27/17 03:20 AM
08/27/17 03:20 AM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Just center the housing and use the 8-3/4 axels, done. Every housing I ever cut down was centered, NEVER a problem. Depending on the tires (slicks), will be how long the 8-3/4 axels last, street car, do it. Only problem with Dana, limited gear choice, no 2.76 ratio. Who would really want a 2.76 ratio in a Dana 60 when the 3.0? ratio is available in the Dana 61 A turbo car would like the 3:00 gear. I'm looking for a 3.90 gear
[Re: NTOLERANCE]
#2360484
08/27/17 09:29 AM
08/27/17 09:29 AM
NTOLERANCE
Madison Wi
Thanks for all the replies. Guess I was over thinking it.
One more question - since I don't have thrust butting and presumably don't need them how much clearance did you set up between the axle and the cross shaft ?
