Motor Mount (Rubber Isolater) #2359752
08/25/17 05:15 PM
08/25/17 05:15 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
Has anyone found an "good" motor mount (the rubber isolater piece). . . just replaced the crap one I used on my Sport Satellite . . .the metal piece with the stud on it, was ONLY bonded to the TOP of the rubber biscuit . . . didn't they used to be made so that piece was in middle of the rubber ?? - doesn't seem like there is much to hold that metal piece to the rubber . . . .
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2359756
08/25/17 05:18 PM
08/25/17 05:18 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I use a solid mount on the drivers side of my engines, even the 318s.
It will never break that way & the two other mounts provide enough cushion that I do not notice any extra vibration.
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2359767
08/25/17 05:41 PM
08/25/17 05:41 PM
a12rag Offline OP
a12rag  Offline OP
This was drivers side - the way engine torques . . .
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2359980
08/26/17 12:42 AM
08/26/17 12:42 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
If you buy the rubber mount for a 70s or 80s pickup, they come with a metal interlock, in case they break the motor won't lift more then a 1/4" - 1/2". The mounts are still rubber and still break much more easily then the old stuff seemed to, but at least you don't loose a fan shroud when they break. Gene
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2360038
08/26/17 06:44 AM
08/26/17 06:44 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2360064
08/26/17 10:35 AM
08/26/17 10:35 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I used the mighty mounts. Pricey but they are not made like the cheap ones. I've had original break just like yours. They have been like that for awhile. Just the bond was better. With this cheap Chinese crap out there, they may not last as long.
Re: Motor Mount (Rubber Isolater) [Re: fastmark] #2360066
08/26/17 10:39 AM
08/26/17 10:39 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I have had the same problem with the new mounts out there. Now I buy NOS mounts, problem solved.
The only Carbs I care about are under the hood!
Re: Motor Mount (Rubber Isolater) [Re: fastmark] #2360115
08/26/17 01:05 PM
08/26/17 01:05 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
In the case of motor mounts, "Chinese crap" would be considerably better than the stuff we're getting out of India these days. Hasn't been a good mount available at a parts store in nearly 20 years...
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2360119
08/26/17 01:26 PM
08/26/17 01:26 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I knew how bad todays stuff was just by looking at it, so I made a cable that goes from the cylinder head ground bolt to the K frame, and painted it Orange. The engine still if free to rock back and forth, but that is all.
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2360121
08/26/17 01:30 PM
08/26/17 01:30 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Not the biscuit style ones for cars like you have pictured there.
Looks like the metal to rubber bond held but the rubber itself failed. Typical in my experience.
Some good solutions posted above, especially for the driver side. I used to break those and the transmission mounts on a regular basis with a slightly worked engine and some racing. I was going to buy the interlocked from Schumacher and Michael suggested using his solid engine strap instead. Haven't broken one since. A pretensioned chain would probably work too. Depends on your preferences and space limitations.
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2360137
08/26/17 01:58 PM
08/26/17 01:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
This is what I use, they are sold in pairs so they do two cars if used on the driver side only.
https://www.summitracing.com/parts/mor-62540/overview/make/dodge
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2360224
08/26/17 06:05 PM
08/26/17 06:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A DIY Fix:
http://www.dodgecharger.com/forum/index.php/topic,13216.0.html
Re: Motor Mount (Rubber Isolater) [Re: John_Kunkel] #2360229
08/26/17 06:24 PM
08/26/17 06:24 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Originally Posted By John_Kunkel
A DIY Fix:
Fixed it CLICK HERE FOR LINK
I did this, so far 4000 miles of abuse & still holding.
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2360534
08/27/17 12:13 PM
08/27/17 12:13 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If Imperial Services still has their poly mounts buy them.Have a set in my 65 that was the first he made.My son had a set in his 62 300 also along with their poly trans mounts.Mine have been in at least 10 years.The aftermatkets lasted maybe a month.They dont break period.That and not as bad as a solid mount for vibration.Rocky
Chrysler Firepower
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2360548
08/27/17 12:44 PM
08/27/17 12:44 PM
a12rag Offline OP
a12rag  Offline OP
All great ideas . . . I like the drilling and bolt idea!! Cheap and relatively easy to do !! My car isn't high torque machine, but don't want the nice underside of the hood touched by the engine!! . . .
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2360581
08/27/17 01:59 PM
08/27/17 01:59 PM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
a person can easily make your own with a bit of welding skill using plate and a formed channell and 2 bolts
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2360998
08/28/17 03:29 AM
08/28/17 03:29 AM
3
340clone Offline
340clone  Offline
I had two break on the driver's side within a few months. I installed a (Schumacher?)torque strap from Mancini and haven't had a problem since. Motor doesn't move as much as it used to either.
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2361508
08/29/17 01:16 AM
08/29/17 01:16 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Here's my poly loc ones. They only caused the suspension and header to hit since I had a strap. I'm seeing if these have a warranty tomorrow and going to buy the Schumacher mount that attaches to the k frame. My uncle and cousin have one on their 11 and 12 seconds cars with the regular auto parts store mounts and no issues. I guess I could be considered lucky it only messed up my TTI headers ugh.
Edit: They said I need to put a heat shield around mine and they have a 3 yr warranty. Also ordered their torque strap while I talked to them.
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2361704
08/29/17 01:53 PM
08/29/17 01:53 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Fir the price of poly locs I think I would search for NOS ones or old stock made in USA ones or do the thru bolt trick or a solid mound on one side. $300 for poly loc mounts seem crazy.
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2361776
08/29/17 03:54 PM
08/29/17 03:54 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
