Jeep Cherokee question #2360162
08/26/17 02:44 PM
08/26/17 02:44 PM
South-east Mn
blaze Offline OP
blaze  Offline OP
South-east Mn
Is the front axle the same between the Cherokee Classic and the Grand Cherokee? Is the Grand Cherokee wider? Are the front drive shafts the same between Grand and Classic? Thank you
Re: Jeep Cherokee question [Re: blaze] #2360219
08/26/17 05:44 PM
08/26/17 05:44 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think the overall housing is the same, but I am not 100%. This would apply only to the ZJ grand not the later WJ. I do know the grands have a different axle joint, they have a CV joint vs a U-joint. Supposedly not as strong but lots smoother when turned tight. I also believe they are low pinion vs the high pinion on the XJ(only up to 99 or 00 after that they went low pinion.
I would guess the front driveshaft to be different.
68 Barracuda Formula S 340
