Re: Need timing chain recommendation
[Re: sixpackgut]
#2358504
08/23/17 11:44 AM
08/23/17 11:44 AM
Posts: 13,493 Marion, South Carolina [><]
an8sec70cuda
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: 1970RT]
#2358515
08/23/17 11:59 AM
08/23/17 11:59 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I need to get a 3 bolt timing chain set for my 470 stroker currently being built. Recommendations would be appreciated. I agree with Cloyes, I use the cam button also, the steel covers are alway pushed out on teardown. Its been my experience that the BB cams do move forward.
Have a great day Iowan
"obsolete is neat"
[Re: 1970RT]
#2358541
08/23/17 12:47 PM
08/23/17 12:47 PM
an8sec70cuda
The last Cloyes timing set (it was a hex-a-just) I bought used a cheap chain that ended up breaking links.
[Re: an8sec70cuda]
#2358706
08/23/17 07:06 PM
08/23/17 07:06 PM
dogdays
[Re: A727Tflite]
#2361736
08/29/17 02:25 PM
08/29/17 02:25 PM
Iowan
Lost in Time
Roller or flat tappet? If roller you need a cam button otherwise there is nothing keeping the cam gear loaded backwards to the block. Flat tappet cams if ground properly load the cam gear to the block. I use flat tappets in my RB race motors, I have been told you don't need a button with my cams by a good friend and engine builder of mine. That was until we tore down my 500 for a refresh. It might have something to do with the rpm,7000 but the covers are pushed out. Cams have been Lunaty or Comp. I've always thought it was from letting off after the lights.?
"obsolete is neat"
