Re: Sb stroker kit?
[Re: MoparBilly]
#2355880
08/18/17 03:43 AM
08/18/17 03:43 AM
Posts: 792 Earth
Rob C
Earth
My question to is, why did you "Assume" so much of the thread starters question? It is a shame you didn't stop to think. You may not want to jump the gun next time and ask yourself what you just read and ask the thread starter some questions before assuming.
Rob, I will continue to assume, jump the gun, and give advice. You know why...because this is a thread! A thread in which the OP is an active participant, so he can provide more info or ask other questions as he sees fit.
You state Rods kit gives you more cubic inches. Does the thread starter "Want more" cubic inches? You said it is a no brainer for you. Does that mean anybody that doesn't want extra cubic inches is dumb?
Not dumb, ignorant. Big difference. If you and all your friends build 4" stroke combos and no one builds a 4.125 or 4.250 deal, how are you supposed to know you need more. The first time I went full throttle in 3rd gear on the street from a 30 mile an hour roll, I KNEW I'd never go back! Instant, gratifying , smile producing torque...it's a beautiful thing.
Is there a problem with Scats equippment that I'm unaware of where it fails after 550hp?
Yes, yes there is, and I'm surprised, considering how observant you are that you are unaware. Granted, My caviat is the assumption we are talking about the less expensive CAST CRANK kits. The crank eventually breaks. The harder and more often you race it, the quicker it will happen.
Your suggesting that he spend more money on better equipment. While I support the notion of using the best equipment available, and I really mean it, purchase the best of what ever you get, IF you can, BUT some of us that actually live in the real world and don't frivolously spend others peoples money via the internet have a wallet to contend with.
Sermon over.
Rob, My brothers and I have built many cars for other people, and we've never spent a dime frivolously, when it's not our money. I live in the real world, I have a 1100 square foot house with a carport, and drive 10 year old paid off cars, so I can spend my money on Hot Rods. That is a life choice I made over thirty years ago, and I've never regretted it once. All the advice I give is first hand, and I'm telling you as plainly as I can, A BPE 428 short block is miles better than a 408/416, especially in a street car. This is similar to the same debate with big blocks, where everyone is quickly moving away from the 4.15 stroke stock rod bearing to the 4.25 stroke 2.20 bearing combo. It was a good sermon, I appreciate your concern. I will continue to make assumptions, and get my hand slapped. So the fact that this is a thread allows you to be OK with assuming? Assume - Ass (out of) U (&) me. Please leave me out of it. You assumed cast crank. I assumed nether. If you needed more info, then ask the thread starter. Don't wait. It's your prerogative to continue to assume if you wish. On the reply of needing or not more stroke, how do you know we need more? We're now ignorant because of what we're happy with? LMAO! Now who is ignorant with assumptions. Really dude! Moving on...... What's wrong with the Scat cranks? Links that read available? No cast crank links please since there not of any concern or part of the topic beside the assuming. I was never talking about them. What does your house have to do with the asked question of the thread starter. Stop patting yourself on the back. Really!?!?! Bragging about a 1100sq/ft house? You are certainly "Some kind of Special" so I leave this to you since I haven no experience with this "Special" you have and do not want to get beat over the head with your long winding road of experience. Thanks a ton.
Re: Sb stroker kit?
[Re: killermopar]
#2355955
08/18/17 11:26 AM
08/18/17 11:26 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Rob C, You missed the humor in my post. You missed the sarcasm in my post. You drug out the old cliches. Thanks, now I know what I'm dealing with, so explaining that smaller rod journals make for an easier installation and a lighter rotating assembly would be a complete waste of time on you, hopefully not the OP.
Let me dumb it down, just for you. If you REALLY want a fast car, you will find a way, even if that includes living below your means. If you aren't willing to spend 700 bucks on a superior product, you're in the wrong hobby/sport period.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
Re: Sb stroker kit?
[Re: MoparBilly]
#2355962
08/18/17 11:35 AM
08/18/17 11:35 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
LOL, to try and get this thread back on topic...What is the difference in the BPE 428 stroker kit and the otherwise "standard" 408-416 kit? I have a 360 LA block sitting in the corner catching dust and may be in the market for a stroker kit soon. Also, as long as we are talking stroker, does a 5.9 magnum block make for a better stroker block?
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
Re: Sb stroker kit?
[Re: killermopar]
#2355982
08/18/17 12:04 PM
08/18/17 12:04 PM
MoparBilly
Phoenix, AZ
The Scat kit, which is over 2K from Summit, has 2.125 rod journals, and features a 6.123 I beam rod with a 2.125 big end and .984 small end.
The Bloomer kit, (I paid 2306 4 year ago), has 2.00 rod journals, and features a 6.200 H beam CompStar rod with a 2.000 big end and 9.27 small end.
The smaller, longer rod, and smaller journals fit in the block easier, allows for a lighter piston (custom built to Your specs.), and a lighter rotating assembly. Even if the cubic inches and torque output were identical, the Bloomer kit is a better value, and a better product. The cubic inches and torque curve are not the same.
Re: Sb stroker kit?
[Re: MoparBilly]
#2355988
08/18/17 12:25 PM
08/18/17 12:25 PM
RapidusMaximus
Weatherford, Texas
Cool, thanks Billy, as to my other question, if any, are there cost/strength/durability, etc, differences between the LA 360 block and the 5.9 block?
Re: Sb stroker kit?
[Re: killermopar]
#2355991
08/18/17 12:30 PM
08/18/17 12:30 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
For the 400-500 difference, that is a no brainer. Lighter, and those compstar rods are sweet. I ran them in my W5 motor for years.
Re: Sb stroker kit?
[Re: MoparBilly]
#2356077
08/18/17 03:06 PM
08/18/17 03:06 PM
Posts: 792 Earth
Rob C
Earth
Let me dumb it down, just for you. If you REALLY want a fast car, you will find a way, even if that includes living below your means. If you aren't willing to spend 700 bucks on a superior product, you're in the wrong hobby/sport period. It is hard to detect humor and nearly impossible for sarcasm. If that were such, then perhaps a smiley face afterwards would help. What old cliches? Actually, you haven't the slightest clue who or what your dealing with or the knowledge, years of experiences ... But you do expose yourself well. After all, it is obvious you know everything. Would you still care to answer me questions or are you just going to continue to evade them? Don't bother to dumb it down for me but for certainly for new guys to the field would benefit from simple explanations. The amount of money spent of a superior product is of no worry to me at all. BUT it may be an issue to someone else who can not afford the higher ticket price. Via your line of thinking (the incredibly thin veiled insult towards me.) Many people should give up there cars because there wallets aren't as deep as yours. People who run, hot rod or race a /6, 273, 318 or 360 engine should hang it up because they don't meet your level of Financial commitment? By not stroking the engine to your level? Of what you think is good and should be done? Who died and made you GOD?!?! Your statement is probably the biggest turn off for people in the hobby, looking to get into the hobby, and stay in it. It says if you don't spend the extra money that "I, MoparBilly deems as mandatory for a real good engine worthy of speech without being belittled, stay home and sell the mopar! It says don't talk to me about your ridiculous and pathetic engine. It says don't talk to me about your ridiculous and pathetic paycheck. Is it don't talk to me because you're ridiculous and pathetic because you're not on my wavelength. And throughout this whole you still can't answer the simple questions that were asked to you. All you're doing is throwing [censored] to see what sticks. I have been with you, nothing is going to stick. If you don't have what it takes to make something stick. And after all of this you still haven't helped the original thread question. Just cast doubt. It seems that is all your good for in this thread. Whatever Billy, whatever...
Re: Sb stroker kit?
[Re: Rob C]
#2356099
08/18/17 03:51 PM
08/18/17 03:51 PM
dogdays
The Philosophy of building stroker engines:
0. Increasing the stroke is nearly always the most optimum way to increase engine size, in terms of cubic inches per dollar.
2. One strokes an engine to increase torque. Torque is what we seek for that "planted in the seat" feeling.
3. As we admit we're building the stroker for more torque, we remember Chuck Senatore's words,"Build the biggest shortblock you can afford." This makes sense. Why limit yourself in your effort to increase torque? Why not build the largest shortblock that you can afford, that has acceptable durability?
4. Bloomer recognized that the LA motor has enough room in it for larger stroke, if you decrease size of rod journals. NASCAR engine builders are making 900+ hp from 355 engines running at 9000rpm, for two hours straight, and they're doing it with 1.889 or 1.850" rod journal. So skipping down to a smaller rod journal on a street engine makes sense. The 2.00" early SBC journal isn't very small, really, and there are a million bearings available for it.
5. So if you cannot afford the 4.125 or 4.250 stroke, build what you can afford, probably the 4.000 stroke. Sometimes that extra $400 IS impossible to get. There's always tomorrow!
R.
Re: Sb stroker kit?
[Re: killermopar]
#2356181
08/18/17 06:45 PM
08/18/17 06:45 PM
B3422W5
Portage,michigan
Pretty sure Rod carries the ' cookie cutter" 4 inch arm kit as well, not just 4.125 and 4.250 kits.
Re: Sb stroker kit?
[Re: killermopar]
#2356188
08/18/17 07:02 PM
08/18/17 07:02 PM
Posts: 792 Earth
Rob C
Earth
Good questions and notation Jbody.
From the author;
"They were on a different 408 and made 640 hp. I don't want to get as crazy, but don't want to kill it right away. It will be used in my pro street satellite, mostly street, but some 1/8 mile passes"
This, to me, suggests the use of forged rotating parts would be the route to travel.
Food for thought & consideration, as well as a question. What was previous HP level in what size engine you drive how long ago in what car? Equipped with what size cam, trans, stall, gear, tire size?
This answer would paint a picture of what was. Helpful info? Possibly.
Then there is the important question of;
Where do you want to go with this 400+ cubic inch W2 headed build? What power level? If you can put a finger on it that is..... 500, 525, 550 hp? Or how fast ET wise you want to travel at! This maybe the toughest question for some to answer, for others, EZ as pie. Knowing the cars equipment, trans gear suspension etc.... would help a lot. When all this info is in, well the idea can come together a lot quicker.
Re: Sb stroker kit?
[Re: Rob C]
#2356199
08/18/17 07:28 PM
08/18/17 07:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
From what I am hearing here.. he wants to use this for a street car and want to run some 1/8 mile stuff... if this is true in a heavy B-body he WOULD like the long arm stroker stuff but at that weight he will need all the help he can get to be quick.. my SB was making 625HP in a light car.. I ran low 9s.. when I built the 405CI W-9 I only added a few more HP but ended up running high 8s.. the big thing was it ran the numbers all the time.. again.. a light car.. yes they are plenty of guys that make more HP but I really didnt need it to run what I did ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Sb stroker kit?
[Re: J_BODY]
#2356395
08/19/17 03:16 AM
08/19/17 03:16 AM
MoparBilly
Phoenix, AZ
sorry Billy.... loved our 4" armed W5 mill. also love our 4" in the R3 ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Either way I'm also in agreement that "IF" you are going through the trouble to do a stroker, you must want something in return and that something is likely more power. Go for the forged crank of your choice. fwiw the iron head 360 we kick to the curb and then throw back in the car when our fun stuff breaks USED to have a cast 360 crank. Last time it was freshened there were a couple of cracks our machinist was concerned about. It served us well, but now there is a forged crank in it. Only a high 10 combo so not too hard on stuff. Jay, 4 inch arm in a race car...certainly, and you have the heads to flow at whatever RPM you choose to make power at. Street car is where the longer arm really shines.
Re: Sb stroker kit?
[Re: killermopar]
#2356401
08/19/17 03:51 AM
08/19/17 03:51 AM
MoparBilly
Phoenix, AZ
Rob C. You are embarrassing yourself really, but by all means if that makes you feel better, go ahead.
I posted an invoice, If you carefully read that invoice, you will realize that Rod Bloomer's kit includes a custom Racetec piston. Bore, ring pack, how far in the hole, dish, valve reliefs ect. To fit YOUR needs. Name a cookie cutter 4" kit that does this and show me the price. The forged crank Scat kits from Summit are $2036. Oh, that's right, YOU determined , "How good Rods kits are, are not in question or up for debate."
Who died and left me god??? I'm not the guy who has tried to moderate this thread and tell everyone else what they can and cannot post from the fifth post on. That would be you. Other than telling people what they can and should post you have not added a single amount of pertinent info at all.
You state that you can't figure out my humor or sarcasm without imojis, then you try to interpret my statements about a short block as an attempt to belittle others? That's a stretch, even for you.
The fact that you think I'm the "deep pockets" guy on here is laughable, and shows you know nothing about me. I've ran simple, budget friendly combo's since day 1.
Rapidus, I have no experience with the magnum blocks, other than the one that went 239 K in my truck.
Re: Sb stroker kit?
[Re: killermopar]
#2356448
08/19/17 09:57 AM
08/19/17 09:57 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
My W2 416 is 10:1 with a 4" Eagle crank. It has a big roller in it and if I didn't already have that 4" crank I think a 4.125 would have been better for it for all the reasons Billy mentioned.
I haven't used a BPE kit but they would for sure be on my list of vendors if I were to do another rotating assembly. I do not know what Molnar offers for rotating assemblies but I do know his customer service is good. We have his Rods in the 416 and they are a nice piece.
68 Barracuda Formula S 340
