741 rear 8 3/4" have a crush sleeve? Pinion Yoke change... #2356880
08/20/17 12:06 AM
08/20/17 12:06 AM
Ohio
lockjaw-express Offline OP
Ohio
I have a 741 8 3/4 Rear housing, and I would like to change out the 7260 Yoke for a 1350 Yoke. That said, is there a crush sleeve, or solid spacer in the 741 stock from the factory?
If it is a crush sleeve, what do I need to do, to change over from a 7260 to a 1350 yoke?
If it has the solid spacer, I guess I am good to go?
Thanks, Mark
Re: 741 rear 8 3/4" have a crush sleeve? Pinion Yoke change... [Re: lockjaw-express] #2356888
08/20/17 12:17 AM
08/20/17 12:17 AM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
No crush sleeve in 741, only 489 case.
Re: 741 rear 8 3/4" have a crush sleeve? Pinion Yoke change... [Re: lockjaw-express] #2356889
08/20/17 12:18 AM
08/20/17 12:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No crush sleeve in those
wave
Re: 741 rear 8 3/4" have a crush sleeve? Pinion Yoke change... [Re: lockjaw-express] #2357004
08/20/17 10:10 AM
08/20/17 10:10 AM
Ohio
Ohio
Great, thanks!
