Oxygen Sensors #2355933
08/18/17 10:45 AM
08/18/17 10:45 AM
usa,pa
jkwedge540 Offline OP
usa,pa
Where do you put Oxygen Sensors on headers with collector mufflers
Re: Oxygen Sensors [Re: jkwedge540] #2355953
08/18/17 11:24 AM
08/18/17 11:24 AM
moparx Offline
moparx  Offline
i would say toward the end of the collectors at the 10 & 2 positions.
beer
Re: Oxygen Sensors [Re: jkwedge540] #2355978
08/18/17 11:52 AM
08/18/17 11:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Try to keep them away from the open air of
the collector.. also keep them upstream of
any input air like a evac.. make sure they
point a little downward so if they get any
condensation on them they will drain off..
what I do is put them in near the front of
the collector but have some space so the gasses
mix before it hits the O2(your after the averages
of that bank otherwise you would put one for each
cyl)
wave
Re: Oxygen Sensors [Re: MR_P_BODY] #2356063
08/18/17 02:40 PM
08/18/17 02:40 PM
usa,pa
usa,pa
I have dynomax collector mufflers on it. Not a lot of room. Would it work in the muffler body itself. Also, need to no a good controler for this to.
Re: Oxygen Sensors [Re: jkwedge540] #2356120
08/18/17 04:15 PM
08/18/17 04:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you run mufflers then you can put it just
before the mufflers.. just make sure its
sealed so you dont suck in air
wave
Re: Oxygen Sensors [Re: jkwedge540] #2359410
08/24/17 11:42 PM
08/24/17 11:42 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I have mine in the header tube , in the collector , you have to make sure there are no leaks or you will not get accurate readings.
Do you have a racepak sportsman ?
....BAD A$$ STREET CAR.....
