Re: 498 Trick Flow Head Carb Tuning
[Re: Dart451]
#2355809
08/18/17 12:22 AM
08/18/17 12:22 AM
Posts: 43,202 Bend,OR USA
Cab_Burge
Fix what is wrong first before changing anything else Changing one thing at a time will get you far better results than two or three things at once What plug numbers are you using? How much total timing are you running now?
[Re: Dart451]
#2355855
08/18/17 02:14 AM
08/18/17 02:14 AM
Posts: 31,042 Oregon
AndyF
I wouldn't use a super soft power valve like 2.5 or 3.5 in a street car. If it was me I'd put a 6 or 6.5 in it and see how it works. Idle vacuum doesn't really matter, the power valve doesn't work at idle it works when the engine gets loaded at higher RPM. Put a vacuum gauge in the car and see what it says when you are cruising down the freeway. It will probably be 13 or 15 or something in that range. If that is the case then a 6 or 6.5 should be fine.
82 jets up front are probably too large but hard to tell without some data. See if you can find a model number on the carb and then jet it like stock. You'll probably want something like a 75 jet + power valve up front and maybe 85 with no power valve out back. Hard to say without knowing more about the carb though.
[Re: Dart451]
#2355917
08/18/17 09:28 AM
08/18/17 09:28 AM
Posts: 667 IL
Dart451
IL
Edit to show holley stock jetting
I will pick up a 6.5 power valve today, change the front jets to 79 and leave the rear at 85
[Re: Dart451]
#2356028
08/18/17 01:26 PM
08/18/17 01:26 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Do yourself a favor....... Buy an A/F ratio gauge.
[Re: Dart451]
#2357392
08/21/17 01:25 AM
08/21/17 01:25 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Check timing with a different light...looks like mark is very close to the thread...you could be of buy a couple degrees.or even more ...
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
