Question about flexplate and external balance motor #2355074
08/16/17 08:48 PM
08/16/17 08:48 PM
Badge Offline OP
Badge  Offline OP
I have a LA 360 motor. It has the 6 bolt rear crank hub. Bolt pattern is symmetrical,so flexplate can be installed several ways. The torque converter has a weight on it for balance. The four mounting bolts on the converter matchup one way on the flexplate. How do you determine how to orient the offset weight if you can mount the flexplate two different ways? Maybe I am over thinking this? Thanks
Re: Question about flexplate and external balance motor [Re: Badge] #2355078
08/16/17 08:59 PM
08/16/17 08:59 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Flexplate will only bolt on crank one way and will only bolt onto the convertor one way.
Re: Question about flexplate and external balance motor [Re: Badge] #2355115
08/16/17 10:14 PM
08/16/17 10:14 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The flexplate in not symmetrical in either the crank or torque converter ends. It will only go on one way.
Don't be the exception.
Re: Question about flexplate and external balance motor [Re: Supercuda] #2355233
08/17/17 01:20 AM
08/17/17 01:20 AM
Badge Offline OP
Badge  Offline OP
I guess I lucked out on choosing the right mount to the crank. Thanks for the info.
