Hose size between regulator and carb
#2354898
08/16/17 03:40 PM
08/16/17 03:40 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
What size hose is recommended between the regulator and the carburetor? -6 or -8? 950hp street car.1150 Dominator.
I thought I heard somewhere not to go too big. Something about the signal at the needle and seat.....
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Hose size between regulator and carb
[Re: Old School]
#2354910
08/16/17 03:56 PM
08/16/17 03:56 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
Either seems to work fine. I use -6 and have seen motor making way more than mine use the same.
[Re: Old School]
#2354912
08/16/17 04:00 PM
08/16/17 04:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I thought I heard somewhere not to go too big. Something about the signal at the needle and seat..... Are you running 2 lines to the carb or 1.. but a #6 is fine
[Re: MR_P_BODY]
#2354919
08/16/17 04:08 PM
08/16/17 04:08 PM
Old School
Virginia Beach, VA
I thought I heard somewhere not to go too big. Something about the signal at the needle and seat..... Are you running 2 lines to the carb or 1.. but a #6 is fine I use 2 lines. I think I will go with -6 lines.
[Re: Old School]
#2354931
08/16/17 04:26 PM
08/16/17 04:26 PM
an8sec70cuda
I should have asked and specified that I also run 2 lines to the carb from the regulator. If I was going to run one single line from the regulator to the carb w/ a fuel log or something similar, I'd probably use a -8 to be safe.
