Re: Which way does coolant flow?
[Re: BDW]
#2355457
08/17/17 02:17 PM
08/17/17 02:17 PM
Posts: 5,886 ohio
ruderunner
ohio
Better in the intake near the thermostat
Angry white pureblood male
[Re: MoparDan]
#2355474
08/17/17 02:36 PM
08/17/17 02:36 PM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
water pump pulls water from the bottom hose (that why its good to have a spring in the bottom hose to keep it from collapsing) At temperature, the thermostat opens allowing heated water through it into the top of the radiator... top to bottom; cooler water would be found at the bottom after it's been air cooled Hot water-air always rise
[Re: floridian]
#2355614
08/17/17 07:16 PM
08/17/17 07:16 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
I am sure there are others but I know some Corvettes ( later years) had reverse flow systems cooling the "hottest" part of the engine first ( heads and top end)... I think the discontinued 4.7 is reverse flow. I know the WP spins in reverse compared to other older Mopars.
[Re: BDW]
#2355674
08/17/17 09:07 PM
08/17/17 09:07 PM
Posts: 5,886 ohio
ruderunner
ohio
Reverse flow systems are certainly getting more common in late model cars. A 340 could be configured that way but not easy.
[Re: ruderunner]
#2355683
08/17/17 09:19 PM
08/17/17 09:19 PM
cudaman1969
fredericksburg,va
Reverse flow systems are certainly getting more common in late model cars. A 340 could be configured that way but not easy. Magnum pump and cover, spun the regular way. Not sure what good it would do. Then again I might be thinking of the 5.7??
[Re: cudaman1969]
#2355688
08/17/17 09:25 PM
08/17/17 09:25 PM
RapidRobert
If you want some good reading on this go to www.moparchat.com then scroll down to & click on "circle track chat" & it is Sanborns' cooling mods that are in a sticky at the top of the page. It'll take you awhile to read thru/grasp it all.
[Re: RapidRobert]
#2355750
08/17/17 10:46 PM
08/17/17 10:46 PM
dogdays
The last Chevy smallblock before the LS motors used reverse cooling. The idea was to get the coolest water to the part that needed cooling the most. That way they could run a little more compression.So the water left the pump into both sides of the block then took a 90 and went up into the head. After the water spread around the head it was metered down into the block by specifically sized holes in head gaskets. The engines had air bleed holes aand tubes at the back ends of the heads. The engine was called LT-1 like the original 370hp 350 from 1970. You can tell the blocks because on the front there are two separate holes on each side where normally there's be only one. Then also the blocks have pretty big holes for the water passage to the heads, at the front inside area of the deck. You can only use the engine with reverse cooling. Read all about it here: http://www.corvetteactioncenter.com/tech...system-526.htmlIt sounded like a good idea at the time, but I'm not sure exactly how well it worked. I guess I'd have to look at an LS engine to see if the reverse cooling idea survived. R.
