'70 Coronet strut bar bushings #235345
02/24/09 09:37 PM
02/24/09 09:37 PM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
Trying to put the lower control arm and strut back on the car. The new bushings i got have a brass sleeve that fit on the strut. But the diameter is too small and doesnt fit around the strut. How do i fix this, or should i just use the old sleeves that were on the car before. Any help would be greatly appreciated.
Re: '70 Coronet strut bar bushings [Re: mkbubs] #235346
02/25/09 12:25 AM
02/25/09 12:25 AM
Mansfield, TEXAS
JOES4FORTY Offline
JOES4FORTY  Offline
Mansfield, TEXAS
Got any photos of what you're talking about?
The GTS Registry!
MOPARTS MEMBER IN PRINT
1969 Dart GTS LS23P9B (First day of production car money pit)
Re: '70 Coronet strut bar bushings [Re: JOES4FORTY] #235347
02/26/09 08:50 AM
02/26/09 08:50 AM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
here is a photo, new sleeve is on the bushings, the old sleeve is next to it.
Re: '70 Coronet strut bar bushings [Re: mkbubs] #235348
02/26/09 10:38 AM
02/26/09 10:38 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
You might try the ole strut rod in the freezer, a little heat on the bushing trick if it just needs a little to fit.
