Page 3 of 4 1 2 3 4
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2355040
08/16/17 06:54 PM
08/16/17 06:54 PM
Cotati, CA
Dave Hall Offline OP
Cotati, CA
Wow! Quite the ordeal there Pittsburgh! I think the engine will be ok for as little as I'm going to run it. It is in some serious need of some lovin'! This winter I will see what I can do to get after it. It's just the same old story... Build a better watch, then we need a parachute and we took 150lbs. off the nose and on and on...
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2355717
08/17/17 09:00 PM
08/17/17 09:00 PM
Cotati, CA
Cotati, CA
Stopped by Sonoma Raceway for some of this on the way back from picking up my cylinder heads.
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2355858
08/18/17 01:18 AM
08/18/17 01:18 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
make you wear a chem suit to pump that stuff in Kali yet? laugh2
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2355874
08/18/17 02:25 AM
08/18/17 02:25 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Ten bux a gallon is cheep. I'm paying $90 a pail for Q16
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2356248
08/18/17 08:49 PM
08/18/17 08:49 PM
Cotati, CA
Cotati, CA
Yep. 9.99 is as high as the pump goes. Good deal I think. My original topic is completely stupid it looks like. Counting the chickens...
I unwrapped my rebuilt 829 lifters and the came in this broken up package with little pieces in all of it. rolleyes
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2356250
08/18/17 08:50 PM
08/18/17 08:50 PM
Cotati, CA
Cotati, CA
Is it ok to use this tool on this engine part?
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2356251
08/18/17 08:54 PM
08/18/17 08:54 PM
Cotati, CA
Cotati, CA
I used this stuff on this and that.
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2356253
08/18/17 08:56 PM
08/18/17 08:56 PM
Cotati, CA
Cotati, CA
Got the heads torqued down.
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2356254
08/18/17 08:56 PM
08/18/17 08:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use them a lot on that type of stuff
wave
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2356258
08/18/17 09:05 PM
08/18/17 09:05 PM
Cotati, CA
Cotati, CA
I'm sitting here enjoying my favorite, ice cold beverage. Still have to screw the plugs in it but I pumped all the fuel out of it and filled it with 116. I added about a gallon and half of distilled water and half a bottle of water wetter. I tightened everything up on top of the manifold and cleaned the carb. I'll wait until tomorrow to fire it and double check what kind of timing I got going on. Last time I set it and phased the dis. It was 34 degrees locked and like I posted before this engine really kind of hates everything but 34.
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2356626
08/19/17 02:50 PM
08/19/17 02:50 PM
Cotati, CA
Cotati, CA
Sooner than previously anticipated. Runs good. Good oil pressure good vacuum. The timing is still at 34.
https://www.facebook.com/dave.hall.90260/videos/10212403445294963/
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2356847
08/19/17 09:54 PM
08/19/17 09:54 PM
AndyF Offline
AndyF  Offline
That is good. Motor sounds nice and ratty.
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2356861
08/19/17 10:20 PM
08/19/17 10:20 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Nice to hear it running again.
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2356931
08/20/17 01:13 AM
08/20/17 01:13 AM
Cotati, CA
Cotati, CA
Taking it to Sacramento tomorrow for the last points race. Nat. Dragster Challenge Wally race.
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2356942
08/20/17 01:32 AM
08/20/17 01:32 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
thought we were going to see if that roloc disc would remove that indy logo laugh2
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2356943
08/20/17 01:33 AM
08/20/17 01:33 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Sac still doomed?
Re: Doesn't look like I'll be back soon... [Re: J_BODY] #2356950
08/20/17 01:58 AM
08/20/17 01:58 AM
Cotati, CA
Cotati, CA
That would be a great tool for that! biggrin
As far as I know, still doomed. I haven't been there since March 19 or something.
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2356957
08/20/17 02:25 AM
08/20/17 02:25 AM
Cotati, CA
Cotati, CA
Here's the car cleaned up and ready to go.
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2357006
08/20/17 09:21 AM
08/20/17 09:21 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Good luck today Dave.
Re: Doesn't look like I'll be back soon... [Re: Dave Hall] #2357429
08/21/17 02:16 AM
08/21/17 02:16 AM
Cotati, CA
Cotati, CA
I had my share of luck. It was pretty cool going 4 rds. after not being in the car for 4 months. Super fun day texting Al all day. My best packs were .023 and .024. I think I secured my spot in the top 5 and will look at the points when they are sorted out over the next couple days. By all of my unofficial accounting I am 4 or 5 which is the accomplishment of the goal I had set when getting this deal back together. I am a little concerned about the oil pressure as the racepak showed oil pressure starting at around 83 pds. when I let go of the button to down around 70lbs. at the 7,200rpm stripe. It was always above where it left at in all previous downloads. I think I might have beat on the bearings a bit as well and was lucky a torched head was the only pitfall. I could have destroyed this thing running that 110 octane fuel and learned a hard lesson. Detonation is NOT your friend. I'll look into pressing some bearings into it before I head towards Vegas.
Page 3 of 4 1 2 3 4
