IBM card decode?? #2352353
08/11/17 11:36 AM
08/11/17 11:36 AM
RI
cudascooter Offline OP
RI
Good morning,
I have a LA built 71 RR and I was told that it would not have a build sheet if it was built there. However I do have what I believe is called the IBM card with all the punch holes. Is there a way to decode this thing?? Thanks in advance.
Re: IBM card decode?? [Re: cudascooter] #2352670
08/12/17 12:15 AM
08/12/17 12:15 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I don't have a firm answer for you, but I think you can put the codes together similar to a build sheet. I assume that there are some threads here on Moparts or somewhere out there that covers decoding the IBM cards, but I'm coming up blank. Maybe if you can scan the card and post an image, someone will chime in on what to look for or how to pull the codes out.
Re: IBM card decode?? [Re: cudascooter] #2352672
08/12/17 12:18 AM
08/12/17 12:18 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Re: IBM card decode?? [Re: cudascooter] #2352747
08/12/17 10:36 AM
08/12/17 10:36 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
LA sheets do exist, so the only way to know if there are any in your car is to search all the normal places.
Re: IBM card decode?? [Re: cudascooter] #2352785
08/12/17 12:00 PM
08/12/17 12:00 PM
GMP440 Offline
GMP440  Offline
This is page 4 from a thread on IBM cards. Shows pic of IBM card and some decoding. Just show numbers and letter decoding. May not tell all of the decoding.
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/39658/4.html
Re: IBM card decode?? [Re: cudascooter] #2352820
08/12/17 01:17 PM
08/12/17 01:17 PM
GMP440 Offline
GMP440  Offline
What year did Chrysler stop using the cards?
Re: IBM card decode?? [Re: cudascooter] #2352875
08/12/17 04:02 PM
08/12/17 04:02 PM
RI
RI
Here is a pic of my IBM card.
