Re: Fuel return line?
[Re: lokalik]
#2352243
08/11/17 01:17 AM
08/11/17 01:17 AM
RapidRobert
I would T near the carbs & run a line from the T to a holley blue reg & use it to regulate the return volume to control the psi at the carb inlet(s) to where I want it (at least several PSI at the carbs at WOT) with (I am assuming) adequate ID lines from tank to carbs for enough vol for your requirements.
[Re: lokalik]
#2352274
08/11/17 03:37 AM
08/11/17 03:37 AM
Posts: 43,352 Bend,OR USA
Cab_Burge
what brand and pressure and volume pump are you using? Some big pumps need the fuel to circulate to keep them cool, others sizes don't Contact the pump maker and ask them about this
[Re: lokalik]
#2352330
08/11/17 10:29 AM
08/11/17 10:29 AM
Posts: 608 TN
1DGEMAN
TN
Electric fuel pump (6pk) is return line required? If yes how would it be connected/ routed. Maybe pics. Thanks This is a very generic question. What is your application? Street, Street Strip, Strip Street or Strip only. Keep in mind the original mechanical pump had a return system .060 return orifice for vapor lock. In most cases a dead head system works just fine. A friends 340 6 pack stock eliminator car found no improvement going to a return system and he went 10.60's many years ago. I am learning that high volume low pressure (below 6psi) works best. I am working on making 3/8 aluminum fuel line to replace 5/16 steel line to each carb on my race engine. My race pump has a bypass built into the pump it is set at 20psi and returns to fuel cell and delivers that pressure to a deadhead regulator set at 5.5psi.
Real Men shift for themselves
[Re: 1DGEMAN]
#2352398
08/11/17 02:23 PM
08/11/17 02:23 PM
Cab_Burge
[quote=lokalik] I am learning that high volume low pressure (below 6psi) works best. I am working on making 3/8 aluminum fuel line to replace 5/16 steel line to each carb on my race engine. My race pump has a bypass built into the pump it is set at 20psi and returns to fuel cell and delivers that pressure to a deadhead regulator set at 5.5psi. The line size from the regulator to the carb. need to be little, not a bunch, bigger inside diameter than the needle and seat size If you are feeding one needle and seat that is smaller than 1/4 inch, .250, then a 5/16 I.D.,.312 is more than big enough I see guys at the track with #8 AN lines feeding the fuel bowls on Holley type carbs, feeding one needle and seat, not needed IMO A #6 or 5/16 I.D. line should feed two .120 needles and seats at WOT with no issues, the bigger the I.D. of the line the more pressure put onto the needle and seat hence needing to reduce the pressure to keep them sealing
[Re: 1DGEMAN]
#2352408
08/11/17 02:49 PM
08/11/17 02:49 PM
Challenger 1
Cincinnati, Ohio
Sorry but you will gain nothing and make your fuel system worse by doing so. Complete waste of time and money. 1 carb does not need 3/8", 3 carbs sure does not. Only thing it will do is slow up the flow of gas and give it more time to heat up.
[Re: lokalik]
#2352409
08/11/17 02:51 PM
08/11/17 02:51 PM
Challenger 1
Cincinnati, Ohio
Electric fuel pump (6pk) is return line required? If yes how would it be connected/ routed. Maybe pics. Thanks What car?
[Re: lokalik]
#2352493
08/11/17 05:47 PM
08/11/17 05:47 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I use a return line on my 455hp 289 64 Fairlane, -8.
Have a great day Iowan
"obsolete is neat"
[Re: lokalik]
#2352496
08/11/17 05:49 PM
08/11/17 05:49 PM
Iowan
Lost in Time
1/2" it's a QuickFuel pump and return regulator.
"obsolete is neat"
[Re: lokalik]
#2352498
08/11/17 05:59 PM
08/11/17 05:59 PM
Iowan
Lost in Time
It drinks fuel like fat man eats hotdogs at a contest, then it does 16 mpg on the highway. Kick the little Ford all you can, 11.50s in drive!
"obsolete is neat"
