Re: TF 904 Transmission Pan Gasket
[Re: DougR]
#2351920
08/10/17 03:32 PM
08/10/17 03:32 PM
Posts: 26,026 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Dealer has the reusable gasket P/N 4295875ac. Be sure the leak is from the gasket and not one of the common sites above the gasket.
[Re: DougR]
#2352157
08/10/17 10:55 PM
08/10/17 10:55 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Dipstick tube is over on that side. Might want to replace the O ring
[Re: TJP]
#2352273
08/11/17 03:34 AM
08/11/17 03:34 AM
RapidRobert
clean it with the car wash wand then keep an eye on it & if need be can even spray some talcum power around it to make it easier to then spot a trail of tranny fluid. someone mentioned a good method of getting the power sprayed up there but I forgot what it was.
[Re: Supercuda]
#2353386
08/13/17 11:25 PM
08/13/17 11:25 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Dipstick tube is over on that side. Might want to replace the O ring I've found a few tubes cracked and leaking in the o-ring area, probably from people bending them during R&R's. Sometimes the spot welds get torn on the tube bracket, also causing leaks.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Supercuda]
#2353881
08/14/17 09:14 PM
08/14/17 09:14 PM
RapidRobert
^^ yes adding a drain plug is a good idea. put it on the side (rear if VB room) & just check before you drill that it ain't interferring with the VB. but dont neglect to after you drain the fluid to pull the pan & clean the bottom/change filter, that it is just to help you contain the sloshing fluid that would be there to be dealt with if there was no drain plug.
