Re: Gas Tank Sending Unit Ground Strap
[Re: GregY]
#2351614
08/09/17 11:34 PM
08/09/17 11:34 PM
Posts: 1,565 tennessee
pushbutton
tennessee
Hi All,
A quick question: the ground strap for the gas tank sending unit is basically just a strap (or wire) that is attached to the fuel line of the sending unit and then again to the fuel line on the other side of the rubber piece that connects the two pieces of hard line, right? This is on a 1971 Charger.
I am having a gauge problem and I think my strap is loose on the sending unit side.
Thanks.
Greg Yep,thats what it does. Maybe you'll get lucky and that is the problem. Good luck.
[Re: GregY]
#2351649
08/10/17 12:15 AM
08/10/17 12:15 AM
RapidRobert
grab your jumper cables & a small jumper wire with alligator clips on each end & connect the batt neg post all the way back to the sender metal nipple itself & see if the gauge straightens out & if it don't, holler back.
[Re: stumpy]
#2351739
08/10/17 08:26 AM
08/10/17 08:26 AM
Posts: 1,210 Rochester, New York
GregY
Rochester, New York
grab your jumper cables & a small jumper wire with alligator clips on each end & connect the batt neg post all the way back to the sender metal nipple itself & see if the gauge straightens out & if it don't, holler back. Thanks Robert, I had heard of this trick, but wasn't smart enough to think of using jumper cables to get from the battery to the rear of the car. Piece of wire and 2 fuel line clamps make the jumper you need. This is what I have now, but I didn't clamp it very well on the sending unit side and now its loose...
[Re: stumpy]
#2351775
08/10/17 11:10 AM
08/10/17 11:10 AM
Posts: 10,777 North Dakota
6PakBee
North Dakota
Piece of wire and 2 fuel line clamps make the jumper you need. I've bought both the stainless repop and the steel repop that are commonly available and they both suck. The stainless has no spring properties and after you snap it around the fuel line it is loose. The steel version is too stiff and you have a devil of a time getting it on. Stumpy's suggestion is indeed a workable one even if not purely stock.
[Re: stumpy]
#2351825
08/10/17 12:37 PM
08/10/17 12:37 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
Piece of wire and 2 fuel line clamps make the jumper you need. This works well to ground the pick-up to the fuel line using single strand copper wire. It works even better if you continue the wire to a solid chassis ground.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: GregY]
#2351844
08/10/17 01:08 PM
08/10/17 01:08 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
I just make up a wire.Then attach it to the sender with a small clamp and the other end I use a small sheet screw to body.Works better than the factory setup.But I dont have show cars so a small screw isnt a problem.Rocky
Chrysler Firepower
[Re: therocks]
#2351922
08/10/17 03:36 PM
08/10/17 03:36 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
""I just make up a wire.Then attach it to the sender with a small clamp and the other end I use a small sheet screw to body.Works better than the factory setup.But I dont have show cars so a small screw isnt a problem""
This is how I made mine too.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
