When you fire up your 60s-early 70s Mopar and let it idle, what exactly do you really know when you look at the ammeter?
The charging system attempts to maintain a specific voltage. On newer vehicles battery temp and other things are factored into that. When you look at your ammeter, do you have any idea if the charging system is actually doing what it supposed to be doing?
I do know. And since I know it, took the time to writte up the thread I wrotte, to explain to everybody.
Neither of the gauges ( voltimeter or ammeter) are perfect. You can get a short on alt and get 18 even 24 volts coming out from the charging system, and the ammeter could show a discharge. It happened to me once! The thuth was it was discharging, not overcharging even the high voltage reading... sooo.... what it was wrong? The ammeter or the voltimeter? Of course both told me there was something wrong, but the fact was it was discharging ( I disconnected the batt and engine stalled ), so the ammeter was telling me the truth not the voltimeter.
If you want a voltimeter, go ahead, but I just try to post a true information, not false. Once you understand how it works will be up to you what do you preffer, but don't take decisions down a false information or unkowledgement of the system.
Myself, and since my car came out from fact with ammeter, I like to keep it like it was from factory. That's what it calls a RESTORATION. Aaaand since IS POSIBLE to make it safe, then decided to keep it. I love my ammeter in working order showing me the charging system status, and not a propportional mirrow reading of the charge system with a voltimeter.
The charge system is about amperes and not volts, so I preffer to read the amperes what is actually what is all about coming and going.
