Re: Last question(for a while) how to set fuel pressure????
[Re: Thumperdart]
#235126
02/24/09 05:46 PM
02/24/09 05:46 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I set mine W/ the engine at idle.
[Re: WILD BILL]
#235133
02/24/09 06:48 PM
02/24/09 06:48 PM
Posts: 1,175 where its cold and white durin...
2QUICK4U
this is how i set mine also.i think alot of racers think fuel delivery issues.i went from holley blue pump to the big aero pump. didnt even change et at all or mph,that was a 500.00 waste.my car went 9.00 flat@158 with blue pump.i had fuel gauge inside car,to read.held pressure all the way.if you can borrow better pump,id go that direction 1st.i dont think its fuel issue.
[Re: Thumperdart]
#235134
02/25/09 03:57 AM
02/25/09 03:57 AM
Posts: 6,293 Northeast, Alpine, NY
9 Sec Phill
On a road near you
On a road near you
This might sound stupid Phil but, I don`t like the look of a radial on a car and like the "old school" slick look #1. and,#2. I hear that they`re a hit and miss tire as far as traction is concerned. So, how much time should it take to fill a gal. jug in 9-10 seconds? I do have a gauge(small)on the ft cowl vent but didn`t get a look to see where my pressure was. Stupid me.
I also like the old school look, but I liked picking up .400 on ET much better, from the slicks to the radails..9.50's sounds better then old school looks to me! I would launch and hit it with 200hp nos off the line and hook every time. Only if the track was real bad, and I mean real bad or late in the season with dew, would I have any problems. If you get a chance try them...Phill
[Re: 2QUICK4U]
#235135
02/25/09 05:55 AM
02/25/09 05:55 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
this is how i set mine also.i think alot of racers think fuel delivery issues.i went from holley blue pump to the big aero pump. didnt even change et at all or mph,that was a 500.00 waste.my car went 9.00 [Email]flat@158[/Email] with blue pump.i had fuel gauge inside car,to read.held pressure all the way.if you can borrow better pump,id go that direction 1st.i dont think its fuel issue.
I had the same results.
[Re: 9 Sec Phill]
#235141
02/25/09 05:52 PM
02/25/09 05:52 PM
Posts: 691 ohio
1Bad440
ohio
9.50's changing to a radail Now Phil don't get his hopes up from just a tire change
[Re: 1Bad440]
#235142
02/25/09 06:25 PM
02/25/09 06:25 PM
Thumperdart
State of confusion
If they would improve that much, I`d be ordering me a set today although I have heard of 1-3 tenths improvements.
[Re: Thumperdart]
#235143
02/25/09 07:02 PM
02/25/09 07:02 PM
Posts: 1,217 Wellington, FL
cudabunch
Wellington, FL
Iam guessing that the 1-3 improvement would be from less rolling resistance of the radial,but he is hitting it hard leaving and doesnt have a 200 shot then comes into play after leaving,then again iam sure a 200 shot would give him a 9.50 or better.
[Re: Thumperdart]
#235144
02/26/09 08:59 PM
02/26/09 08:59 PM
Thumperdart
State of confusion
Just for giggles I decided to crank up the fuel pressure as much as it would go until it sputtered or missed but it didn`t so I stopped at 9 psi. and left it. Per Continental Converters instructions I took my car out and at 2000 rpm`s in 3rd gear I mashed the gas and it flashed to around 4000-4500 then blew the tires off. Is there another way to check a vert other than the rpm`s mph math deal? Thankxx..
