Last question(for a while) how to set fuel pressure???? #235125
02/24/09 05:43 PM
02/24/09 05:43 PM
State of confusion
Thumperdart Offline OP
State of confusion
Since that race I`ve talked to several people about the carb, jets, bleeds pressure etc. So, what`s the PROPER way to set it? One guy says to disconnect one fuel line from the bowl, put it in a jug and fire up the pump and set it that way. Is this correct? Thankxx........
Re: Last question(for a while) how to set fuel pressure???? [Re: Thumperdart] #235126
02/24/09 05:46 PM
02/24/09 05:46 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I set mine W/ the engine at idle.
Re: Last question(for a while) how to set fuel pressure???? [Re: WILD BILL] #235127
02/24/09 05:48 PM
02/24/09 05:48 PM
State of confusion
State of confusion
That`s the way I`ve always done it but an "EXPERT" said to relieve one line THEN flow it(not running)and that gives the most accurate volume amount.
Re: Last question(for a while) how to set fuel pressure???? [Re: Thumperdart] #235128
02/24/09 05:51 PM
02/24/09 05:51 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
I was taught to bring up the pressure untill it blows the needles off the seats and then back it down a 1/4 PSI. Once this is done then do a flow test....Phill
Re: Last question(for a while) how to set fuel pressure???? [Re: 9 Sec Phill] #235129
02/24/09 05:53 PM
02/24/09 05:53 PM
State of confusion
State of confusion
I think the same guy(Cab)may have taught us both that trick.
Re: Last question(for a while) how to set fuel pressure???? [Re: Thumperdart] #235130
02/24/09 06:01 PM
02/24/09 06:01 PM
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
I wish you would try some ET street radails on that dart of yours....You might be pleased with the results....Phill
Re: Last question(for a while) how to set fuel pressure???? [Re: Thumperdart] #235131
02/24/09 06:05 PM
02/24/09 06:05 PM
Kalamazoo, MI
StrokedW7 Offline
StrokedW7  Offline
Kalamazoo, MI
Your doing it right... Do you have a gauge you can monitor going down the track? That is even better yet.
I have done a test, like your friend is suggesting, to see if the pump is providing enough volume but that is differet than pressure.
Steve
Steven M. Hamacher, CPA, MST
For ALL your tax, accounting, and payroll needs
www.Kalamazoo-CPA.com
Re: Last question(for a while) how to set fuel pressure???? [Re: 9 Sec Phill] #235132
02/24/09 06:27 PM
02/24/09 06:27 PM
State of confusion
State of confusion
This might sound stupid Phil but, I don`t like the look of a radial on a car and like the "old school" slick look #1. and,#2. I hear that they`re a hit and miss tire as far as traction is concerned. So, how much time should it take to fill a gal. jug in 9-10 seconds? I do have a gauge(small)on the ft cowl vent but didn`t get a look to see where my pressure was. Stupid me.
Re: Last question(for a while) how to set fuel pressure???? [Re: WILD BILL] #235133
02/24/09 06:48 PM
02/24/09 06:48 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
this is how i set mine also.i think alot of racers think fuel delivery issues.i went from holley blue pump to the big aero pump. didnt even change et at all or mph,that was a 500.00 waste.my car went 9.00 flat@158 with blue pump.i had fuel gauge inside car,to read.held pressure all the way.if you can borrow better pump,id go that direction 1st.i dont think its fuel issue.
Re: Last question(for a while) how to set fuel pressure???? [Re: Thumperdart] #235134
02/25/09 03:57 AM
02/25/09 03:57 AM
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
I also like the old school look, but I liked picking up .400 on ET much better, from the slicks to the radails..9.50's sounds better then old school looks to me! I would launch and hit it with 200hp nos off the line and hook every time. Only if the track was real bad, and I mean real bad or late in the season with dew, would I have any problems. If you get a chance try them...Phill
Re: Last question(for a while) how to set fuel pressure???? [Re: 2QUICK4U] #235135
02/25/09 05:55 AM
02/25/09 05:55 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
this is how i set mine also.i think alot of racers think fuel delivery issues.i went from holley blue pump to the big aero pump. didnt even change et at all or mph,that was a 500.00 waste.my car went 9.00 [Email]flat@158[/Email] with blue pump.i had fuel gauge inside car,to read.held pressure all the way.if you can borrow better pump,id go that direction 1st.i dont think its fuel issue.
I had the same results.
Re: Last question(for a while) how to set fuel pressure???? [Re: 493_DART] #235136
02/25/09 12:54 PM
02/25/09 12:54 PM
2QUICK4U Offline
2QUICK4U  Offline
thump do you run a trans brake?sounds like air conditions and track conditions were changing on you.car leaves pretty hard.is that a ladder bar car or leaf springs.when we talked at fontucky i dont remeber looking over you car.
Re: Last question(for a while) how to set fuel pressure???? [Re: 2QUICK4U] #235137
02/25/09 01:18 PM
02/25/09 01:18 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
I set mine to 7 psi at Idle and monitor it during a pass to see if it holds. I had a Holley black pump in the car and the needle did move a little while going down the track. I put in a Magnafuel 500 pump ans saw zero change in ET or mph. The needle does not move anymore...
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: Last question(for a while) how to set fuel pressure???? [Re: 2QUICK4U] #235138
02/25/09 01:45 PM
02/25/09 01:45 PM
State of confusion
State of confusion
Thankxx guys.......I might try some radials in the future but the starting lines not the problem as you can see/hear it`s going down the track. I talked to Chris at Continental Converters and asked him to view the vid and tell me if he sees or hears anything that could be vert related and I`m going to confirm my flash stall and go from there. I`m also going to set my fuel pressure as high as it will go w/out blowing the needle and seat off and go from there. Might even try shifting at 7000 since the higher I shift, the faster it goes. My suspension is the cal-tracs set up w/5-way ranchos w/out a break since I still have stock caps on my 8 3/4.
Re: Last question(for a while) how to set fuel pressure???? [Re: Thumperdart] #235139
02/25/09 04:58 PM
02/25/09 04:58 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Where do you set your carb float levels? I usually run the see thru plugs on my bowls so I can set the fuel level half way up the sight plug. One other thing to remember!!! don't go crazy and make a bunch of changes at the same time. The car runs great and you are just fine tuning to find that little extra.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Last question(for a while) how to set fuel pressure???? [Re: pittsburghracer] #235140
02/25/09 05:19 PM
02/25/09 05:19 PM
State of confusion
State of confusion
I have the plastic see through plugs also and set em at the bottom not the middle like yourself as I was told to do by many. I try to only make one change at a time unless I know I`m only going to get a few runs in. Thankxx.........
Re: Last question(for a while) how to set fuel pressure???? [Re: 9 Sec Phill] #235141
02/25/09 05:52 PM
02/25/09 05:52 PM
ohio
1Bad440 Offline
1Bad440  Offline
ohio
9.50's changing to a radail
Now Phil don't get his hopes up from just a tire change
Re: Last question(for a while) how to set fuel pressure???? [Re: 1Bad440] #235142
02/25/09 06:25 PM
02/25/09 06:25 PM
State of confusion
State of confusion
If they would improve that much, I`d be ordering me a set today although I have heard of 1-3 tenths improvements.
Re: Last question(for a while) how to set fuel pressure???? [Re: Thumperdart] #235143
02/25/09 07:02 PM
02/25/09 07:02 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Iam guessing that the 1-3 improvement would be from less rolling resistance of the radial,but he is hitting it hard leaving and doesnt have a 200 shot then comes into play after leaving,then again iam sure a 200 shot would give him a 9.50 or better.
Re: Last question(for a while) how to set fuel pressure???? [Re: Thumperdart] #235144
02/26/09 08:59 PM
02/26/09 08:59 PM
State of confusion
State of confusion
Just for giggles I decided to crank up the fuel pressure as much as it would go until it sputtered or missed but it didn`t so I stopped at 9 psi. and left it. Per Continental Converters instructions I took my car out and at 2000 rpm`s in 3rd gear I mashed the gas and it flashed to around 4000-4500 then blew the tires off. Is there another way to check a vert other than the rpm`s mph math deal? Thankxx..
