Re: Temperature Gauge
[Re: ct440rod]
#2351557
08/09/17 09:20 PM
08/09/17 09:20 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Home made mixture of 50% ATF and acetone works GREAT
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: BDW]
#2351630
08/09/17 11:50 PM
08/09/17 11:50 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Aluminum or iron manifold? If aluminum, it's not coming out. Be a hell of a trick to get a water temperature sender to work in a 440 intake. I think you meant water pump housing As for the paint, doesn't really matter it's going to crack when you pull the plug out, if you can. May as well accept that.
[Re: BDW]
#2351652
08/10/17 12:19 AM
08/10/17 12:19 AM
RapidRobert
If the penetrating oil over several days did not work then I would use a torch & some candle wax.
[Re: BDW]
#2351940
08/10/17 04:07 PM
08/10/17 04:07 PM
Posts: 395 Milan Ohio
ct440rod
Milan Ohio
I took out the original sending unit out but hole is to small for mechanical sending unit .. There is a 1/2" plug by the 2 hoses that go to the heater core.
