Springs for magnum heads #2350357
08/07/17 10:57 PM
08/07/17 10:57 PM
Louisiana
Jason73 Offline OP
Jason73  Offline OP
Louisiana
Hey, how's it going. I'm trying to replace the stock 5.9 magnum springs on a 2001 motor. I noticed in an old post it was mentioned that Hughes 1110 springs can be used with 2.2l retainers, or can use gm springs. I've got a .478 lift so either way should work. What motor/car can the gm springs be found on that work? Also what 2.2l motor for the retainers? Is that the gm 2.2l or dodge 2.2l thanks for your help. I didn't want to revive an old post for this info.
1972 challenger
Re: Springs for magnum heads [Re: Jason73] #2350363
08/07/17 11:05 PM
08/07/17 11:05 PM
Welcome here Jason, now that you mention it yes I remember that article from way back & perfect timing as I have some 5.2 mag heads that I might want to revive. Hang loose, you will get some answers.
Re: Springs for magnum heads [Re: RapidRobert] #2350366
08/07/17 11:10 PM
08/07/17 11:10 PM
Louisiana
Jason73 Offline OP
Jason73  Offline OP
Louisiana
Thanks! Glad to be here.
1972 challenger
Re: Springs for magnum heads [Re: RapidRobert] #2350461
08/08/17 01:22 AM
08/08/17 01:22 AM
If you can post that old info I'd sure like to see it (or a link to it). I just measured the spring pockets on my 5.2 OE mags & they are narrow (I left the sheet in the garage) but the dia is way less than 1.5" which I believe I read is a good move to "open the pockets up to use common 1.5" springs" & the parenthesis quote was what I read regarding this which is why I went & measured mine yesterday. I'll grab (& post) the note tomorrow.
Re: Springs for magnum heads [Re: Jason73] #2350471
08/08/17 01:39 AM
08/08/17 01:39 AM
Louisiana
Jason73 Offline OP
Jason73  Offline OP
Louisiana
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/757473/gm-beehive-springs.html
That is a link to the old post I was reading. I'm hoping someone might know which 2.2l motor/car to look for the retainers, and which car/ motor for the gm 3100 springs. Lots of good info, just hope to get some clarification. Thanks
1972 challenger
Re: Springs for magnum heads [Re: Jason73] #2350477
08/08/17 01:45 AM
08/08/17 01:45 AM
thank you for the info. I do not have an answer for your (2) questions.
Re: Springs for magnum heads [Re: RapidRobert] #2350675
08/08/17 01:05 PM
08/08/17 01:05 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
patrick would be the goto guy for this but he has not posted in three years. I took a lot of his advice in my 5.2L Magnum build but for the springs I used the stock ones that came with my Engine Quest heads. Hughes still has them and may have information on spring seat diameter.
Craig
Re: Springs for magnum heads [Re: denfireguy] #2350689
08/08/17 01:23 PM
08/08/17 01:23 PM
Are those his 1110's
Re: Springs for magnum heads [Re: Jason73] #2350736
08/08/17 02:53 PM
08/08/17 02:53 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
I tried to install the Hughes 1110's on my magnum heads and they were too tight/hit on several of them. It is likely due to casting flash/production tolerances on spring pockets or whatever because it was not on all of them. I had purchased the whole retainer/lock/spring kit. When I use them in the future I'll be installing them off the car to check and clearance the spring pockets.
Re: Springs for magnum heads [Re: Jason73] #2350902
08/08/17 07:16 PM
08/08/17 07:16 PM
Louisiana
Jason73 Offline OP
Jason73  Offline OP
Louisiana
Baxter what did you end up going with if they were to tight?
1972 challenger
Re: Springs for magnum heads [Re: Jason73] #2350910
08/08/17 07:33 PM
08/08/17 07:33 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
Just used the stock springs, many suggested my cam didnt "require" aftermarkets springs so I gave it a shot
Re: Springs for magnum heads [Re: Baxter61] #2350967
08/08/17 09:02 PM
08/08/17 09:02 PM
Louisiana
Jason73 Offline OP
Jason73  Offline OP
Louisiana
How high is your lift that you could stick with stock springs? If you still have the Hughes I'd be interested in buying them to try
1972 challenger
Re: Springs for magnum heads [Re: Jason73] #2351138
08/09/17 02:28 AM
08/09/17 02:28 AM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
.480 lift, I was told my cam is the biggest you can go with stock springs and the stock computer
Re: Springs for magnum heads [Re: Baxter61] #2351712
08/10/17 03:32 AM
08/10/17 03:32 AM
My OE 5.2 assembled mag heads, the springs are 1&5/16" as best as I could measure with em installed.
Re: Springs for magnum heads [Re: Jason73] #2352573
08/11/17 08:06 PM
08/11/17 08:06 PM
Youngstown
Vincenzo Offline
Vincenzo  Offline
Youngstown
Try magnummopar.com his 550 spring kit should be a plug and play for you.
Woodruff Carburetor Specialties
330-799-9479
Re: Springs for magnum heads [Re: Vincenzo] #2353734
08/14/17 05:17 PM
08/14/17 05:17 PM
dogdays Offline
dogdays  Offline
There isn't a whole lot of room in there.
Rockauto has the Enginetech ERV901 for $2.01 each. It's the same as a 340 stock spring. solid height is 1.1"
Rockauto also lists a tapered spring for 5.2 Mag but no real information on it.
I have seen the Buick tapered springs on Ebay for not much but I cannot remember what retainer goes with them. However, I think Patrick turned away from them. Seat load is a little low for a performance cam.
He posted here within the last month.
R.
