Swap power steering to manual steering Bill of Materials???
#2350035
08/07/17 01:36 PM
08/07/17 01:36 PM
Posts: 111 Connecticut, USA
MRGTX
Connecticut, USA
I assume this would be a similar list across all classic Mopar platforms but if it matters, this is a '73 A-body.
I understand that the steering column/shaft (?) is longer for manual cars...but the adaptors (from Mancini, etc.) are a safe option, correct?
Will the power steering pitman arm still work? What other linkage parts will need to be swapped?
Any advantages to going with a pricier/updated Flaming River or Firmfeel box rather than a rebuilt OEM unit?
Does anyone regret going with a "quick ratio" 16:1 box? Is it too heavy?
Anything else a fella should know?
Thanks for any info!! -Mike
Re: Swap power steering to manual steering Bill of Materials???
[Re: MRGTX]
#2350068
08/07/17 02:21 PM
08/07/17 02:21 PM
MRGTX
Connecticut, USA
Interesting info, Dave. Thank you! I'm surprised about the pitman arm being compatible...that's very good news. I'm also working on a Dart Sport (picture attached). I have Doug's Headers which work fine with the linkage for the auto trans...it sounds like the Flaming River coupler might be a requirement for me too. The cable shifter was only a requirement because of your headers, right? I can't imagine how the steering box would be relevant but just want to make sure I understood.
[Re: MRGTX]
#2350072
08/07/17 02:27 PM
08/07/17 02:27 PM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
Is that buckets or a split bench? Nice car!
[Re: MRGTX]
#2350097
08/07/17 03:00 PM
08/07/17 03:00 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Depends on the year/model of the manual box donor.
The 73 A body has two different pitman arms depending on power or manual.
IIRC, C body (nd truck/van) manual boxes used the same sized output shaft as the A body power boxes, but the A body manual box used a smaller diameter output shaft, hence the need for a different pitman arm. I believe B bodies boxes follw the A body ones in output shaft sizing.
[Re: Supercuda]
#2350121
08/07/17 03:36 PM
08/07/17 03:36 PM
MRGTX
Connecticut, USA
Is that buckets or a split bench? Nice car! Thanks! It photographs better than it looks in person. Most of the paint is original and it shows. It has a split bench. The seats are in good shape...but I'm in the process of finding period-correct looking black vinyl sports car seats. This probably means 240/260z seats...which are all trashed by now! :p How's your car set up? Depends on the year/model of the manual box donor.
IIRC, C body (nd truck/van) manual boxes used the same sized output shaft as the A body power boxes, but the A body manual box used a smaller diameter output shaft, hence the need for a different pitman arm. I believe B bodies boxes follw the A body ones in output shaft sizing. Ah... this makes sense. Much appreciated!
