Trunk Decal Removal #2345851
07/30/17 07:39 PM
07/30/17 07:39 PM
Central Texas
b_body_fan Offline OP
Central Texas
What is the best method for removing the jack instructions decal on the underside of the trunklid without damaging the paint? The paint and decal are only a couple years old and in excellent condition. Unfortunately, the decal is wrong for the year of the car. When it was painted the wrong decal was installed and I didn't realize it until recently. Should I use a rubber decal wheel or a solvent such as Goo-Gone?
Re: Trunk Decal Removal [Re: b_body_fan] #2345855
07/30/17 07:48 PM
07/30/17 07:48 PM
md
mopars4ever Offline
mopars4ever  Offline
md
WD40 has worked for me in the past.
Re: Trunk Decal Removal [Re: b_body_fan] #2345864
07/30/17 08:07 PM
07/30/17 08:07 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
This is an air freshener.
For whatever reason known only to the gods, it works awesome for label softening & adhesive remover.
http://www.homedepot.com/p/Pure-Citrus-6-25-oz-Orange-Air-Freshener-NA222/202528023
Re: Trunk Decal Removal [Re: b_body_fan] #2347432
08/02/17 06:36 PM
08/02/17 06:36 PM
MA
steve70 Offline
steve70  Offline
MA
heat it with a hair dryer and slowly pull it off.
1970 Challenger T/A 4 speed
Re: Trunk Decal Removal [Re: Alaskan_TA] #2347711
08/03/17 04:20 AM
08/03/17 04:20 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Most orange cleaners will work
Re: Trunk Decal Removal [Re: b_body_fan] #2347762
08/03/17 10:44 AM
08/03/17 10:44 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
can't you glue the correct one over the incorrect one? Aren't they the same size?
Of course if the glued decal is still nice and straight, because with time they get wrinkled with the heat
Re: Trunk Decal Removal [Re: NachoRT74] #2348552
08/04/17 05:27 PM
08/04/17 05:27 PM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
In the past I've used a wet sponge or wash cloth and once it started to wrinkle, just use my thumb nail to slowly scrape it off.
Re: Trunk Decal Removal [Re: NachoRT74] #2348828
08/05/17 07:19 AM
08/05/17 07:19 AM
Central Texas
Central Texas
The correct decal is slightly smaller the the one installed so I won't be able to cover it up. I will try the air freshener trick. Citrus has a natural glue removing property.
Re: Trunk Decal Removal [Re: b_body_fan] #2348830
08/05/17 07:52 AM
08/05/17 07:52 AM
Pennsylvania
P
polaris400cc Offline
P
Pennsylvania
I use n-heptane. Not sure if it's available in that name off a store shelf.
Over the counter stuff that I have used and had success.
Wd-40
Goo gone
Liquid wrench
Pb-blaster
But n-heptane works better than these
Re: Trunk Decal Removal [Re: b_body_fan] #2349223
08/05/17 11:57 PM
08/05/17 11:57 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The correct stuff for the job..A hair dryer or heat gun to pull the vinyl plus this stuff and it's an easy job with no potential damage...
