Re: 440 source heads [Re: Wedgeman] #2348539
08/04/17 05:01 PM
08/04/17 05:01 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The calculated flow for the curtain area of a 2.14 valve, .100 lift @ 100% c/d(like flowing a straight tube)is right about 100cfm.
Typical c/d at low lifts is 60-80%.
Re: 440 source heads [Re: fast68plymouth] #2348555
08/04/17 05:33 PM
08/04/17 05:33 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
that said, it seems the flow #'s from the facebook pic grab could start at .200" lift...
or bench could need calibration, really no telling without more info..
Re: 440 source heads [Re: krautrock] #2348561
08/04/17 06:00 PM
08/04/17 06:00 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Here are the full curve comparisons...
Larry Smith's posted #s assuming the lowest #s are .100":
.100" - 120
.200" - 177
.300" - 239
.400" - 282
.500" - 312
.600" - 324
Or, assuming the lowest #s are .200" (which I don't believe to be the situation):
.200" - 120
.300" - 177
.400" - 239
.500" - 282
.600" - 312
.700" - 324
MCH's CNC Stealth program advertised #:
.100" - 75.0
.200" - 156.7
.300" - 219.8
.400" - 266.2
.500" - 298.8
.600" - 314.9
.700" - 320.7
I can't add anything more to this topic, and still question the bench calibration or some other condition that's resulting in unrealistic low-lift #s.
Regardless, carry on with your bad self! grin
Re: 440 source heads [Re: Wedgeman] #2348590
08/04/17 07:05 PM
08/04/17 07:05 PM
So. Burlington, Vt.
So. Burlington, Vt.
My total guess is...... There's a leak, causing the big low lift numbers.
Re: 440 source heads [Re: Wedgeman] #2348594
08/04/17 07:18 PM
08/04/17 07:18 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
the only reason to have Stealth heads is for the stock look. if you should ever damage a Stealth head & it requires welding, you might as well throw it in the bin & buy a new one. They're cast from a low grade aluminium that does not respond well to welding. I have repaired a set of Stealths that needed welding but the cost was more than a new head. go figure.
Re: 440 source heads [Re: Wedgeman] #2348599
08/04/17 07:25 PM
08/04/17 07:25 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
This is what I got out of my Super Stealths on my bench
OOTB
.200 140
.300 202
.400 242
.500 256
.600 267
.700 267
after
.200 157
.300 217
.400 264
.500 290
.600 314
.700 335
.800 345
Re: 440 source heads [Re: Wedgeman] #2348624
08/04/17 08:07 PM
08/04/17 08:07 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Originally Posted By Wedgeman
Miles away from the Edelbrock
stuff !!
Which way?
Re: 440 source heads [Re: Wedgeman] #2348710
08/04/17 10:44 PM
08/04/17 10:44 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mine have been on since they came out.They get beat on pretty good.I did change springs,retainers, and keepers because i run a 588 solid cam and 4 speed.My machinist did some clean up and like the look.He was a perfectionist.Happy with them and i needed straight plugs for my dome pistons.Rocky
Chrysler Firepower
Re: 440 source heads [Re: Wedgeman] #2348772
08/05/17 01:20 AM
08/05/17 01:20 AM
Granbury TX
Prochargedmopar Offline
Granbury TX
Ask him on his fb page.
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Re: 440 source heads [Re: Wedgeman] #2348919
08/05/17 12:48 PM
08/05/17 12:48 PM
So. Burlington, Vt.
So. Burlington, Vt.
I know flow bench #s can't be compared DIRECTLY, but when they're using a common calibration standard you can expect they're going to be REASONABLY close.
Case in point....... I flowed one of the MCH CNC ported stealths about 5 years ago.....
.100---72
.200--159
.300--220
.400--266
.500--293
.600--309
.700--313
The thing that's almost never mentioned, and would have more of an impact on the higher lift flow, especially as the flow numbers get bigger......is the shape of the radius for the air inlet.
This can result in a 1-3% difference in flow(or more if its a particularly bad one) on the same head, on the same bench.
