Page 8 of 9 1 2 3 4 5 6 7 8 9
Re: Weird MoPar interchangability..... [Re: dennismopar73] #23474
06/15/11 09:09 PM
06/15/11 09:09 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
front end off my 70 dart will bolt
on my 75 duster perfect fit
so does the pass and drivers doors
now i can have wing windows on my duster??
The window glass is totally different from the Duster/Demon/Dart Sport cars compared to the Hardtop or sedan models. You cannot have vent windows in a Duster.
The headlight door motor from a mid 70s and up Chrysler will work in a 70 Charger.
Omni/Horizon rear arm rest pads are the same as 73-76 2 door A body cars.
The brake master cylinders will interchange many, many years including the mid 70s to early 80s aluminum body units.
the 67-72 Valiant rear bumper will fit a 67-69 Dart, but the contours are different.
69 Valiant grille fits a 70-72 Duster/Valiant with minor mods.
FMJ cop car rear sway bars will fit into 67-76 A bodies with minor mods.
73-87 Chevy trucK front sway bars will fit in 70-72 B bodies and 73-76 A bodies with minor mods. These bars were either 1 inch or 1.25 depending on 1/2 or 3/4-1 ton rating.
70 Charger front turn signal lenses are the same as 70-74 Challengers.
Re: Weird MoPar interchangability..... [Re: Kern Dog] #23475
06/15/11 11:58 PM
06/15/11 11:58 PM
Morningside
AdventurerSport Offline
waaaay out there in left field
Morningside
Speaking of Chevys, many years Dodge trucks used Saginaw (GM) power steering pumps, the same units used by Chevy/GMC trucks of the same years.
Chevy/GMC 4x4s have used New Process/New Venture Gear transfer cases (Chrysler) for many years. In the '70s, all the Big 3 (including Ford) used the NP203 full time t-case in the same years (75-79)
Although, the same basic internals but not the exact same unit, as they are married to the transmission and specific each to Dodge, GM and Ford. Ford used an opposite side case, too, with the front driveshaft on the driver's side, whereas Dodge and GM used cases with the front shaft on the passenger side. Front driveshafts interchange between Chevy and Dodge in those years. Front axles interchange, but are not the same, as they use different brakes, hubs and bearings.
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: Weird MoPar interchangability..... [Re: AdventurerSport] #23476
06/16/11 01:36 AM
06/16/11 01:36 AM
South Dakota
uponblocks Offline
uponblocks  Offline
South Dakota
I've read that the C body big block oil pans with the notch to clear the tie rods work well in A bodys, and also to convert F/M/J body to big block.
72-93 trucks use the same hood hinges as 66-70 B bodys.
I also used a 68-69 b body turn signal switch in my 1971 D100.
Re: Weird MoPar interchangability..... [Re: uponblocks] #23477
06/16/11 10:19 PM
06/16/11 10:19 PM
Morningside
Morningside
Aren't early Viper six lug hubs the same as the Dakota in those years?
JS
Re: Weird MoPar interchangability..... [Re: AdventurerSport] #23478
06/16/11 10:26 PM
06/16/11 10:26 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
60s and 70s Ford P/Us have same drums and wheel bearings and wheel as early Imperials.
Re: Weird MoPar interchangability..... [Re: mopar_man] #23479
06/16/11 10:34 PM
06/16/11 10:34 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Aussie 2bbl slant sixes used max wedge air cleaner lids of course...
Re: Weird MoPar interchangability..... [Re: OzHemi] #23480
06/17/11 09:16 PM
06/17/11 09:16 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
'70 Charger R/T grille "R/T" emblem is same size as '71 Charger R/T fender and trunk emblem. Just have to remove the posts to use on the '71. Still hard to find.
Re: Weird MoPar interchangability..... [Re: NicksGarage] #23481
06/17/11 09:22 PM
06/17/11 09:22 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
'66-67 b-body sedan and wagon gas tank fits '68-69 b-body wagons. Not sure about '70 due to emissions.
See this thread. https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: Weird MoPar interchangability..... [Re: NicksGarage] #23482
06/18/11 08:44 AM
06/18/11 08:44 AM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
I'm not sure if this is obvious or not. 1971-73 Coronet parking lamp lenses are the same as a 1970 Coronet.
I'm running an 80's Caravan 2 speed wiper motor in my 1972 Coronet. It works perfect and even parks the hideaway wipers.
No longer taking $h!t from anyone!
Re: Weird MoPar interchangability..... [Re: DUFFMAN] #23483
06/18/11 10:41 AM
06/18/11 10:41 AM
Morningside
Morningside
Many year wiper motors are the same, especially 72-93 trucks, and early model Dakotas, all those years interchange well.
JS
Re: Weird MoPar interchangability..... [Re: AdventurerSport] #23484
06/18/11 11:28 AM
06/18/11 11:28 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
JS
Yes the Saginaw 808 box. Columns are very simuler too.
I put Chevy disc brakes on my 73 W200. All the Chevy stuff bolted right to the Dodge knuckles
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Weird MoPar interchangability..... [Re: moparmarks] #23485
06/19/11 06:44 PM
06/19/11 06:44 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
67-68 Dart 2dr. sedans shared the same doors with th 67-69 valiant 2 drs.
Re: Weird MoPar interchangability..... [Re: pauly v.100] #23486
06/19/11 10:11 PM
06/19/11 10:11 PM
Morningside
Morningside
1980s Dodge trucks with tilt steering columns used GM columns for many years, including GM style keys and lock cylinders.
JS
Re: Weird MoPar interchangability..... [Re: AdventurerSport] #23487
06/19/11 10:15 PM
06/19/11 10:15 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
JS
My 79 Maxivan has a GM column. And a key just like my 72 Duster.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Weird MoPar interchangability..... [Re: Rug_Trucker] #23488
06/19/11 10:51 PM
06/19/11 10:51 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
only skimmed through the thread but did anyone mention that the '68 - '70 B-body Dodge and Plymouth doors (Sat, Belv, RR, GTX, Cor, R/T, Sup Bee,....) are the same except for the lock button position on the '68's.........and I think if it wasn't for the "scallops" on the Charger doors the same would apply there too....
Re: Weird MoPar interchangability..... [Re: A12] #23489
06/19/11 10:53 PM
06/19/11 10:53 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
'69 A12 high idle solenoid is a Delco-Remy part used on a Pontiac too
Re: Weird MoPar interchangability..... [Re: A12] #23490
06/19/11 11:30 PM
06/19/11 11:30 PM
El Cerrito Ca.
gregn96cuda Offline
gregn96cuda  Offline
El Cerrito Ca.
7 1/4" rear axle fill plugs on the back cover are the same as max wedge intake plugs.
Re: Weird MoPar interchangability..... [Re: gregn96cuda] #23491
06/20/11 01:34 PM
06/20/11 01:34 PM
grande prairie , ab , canada
68notch Offline
68notch  Offline
awesome topic
truck stepside fenders are the same from 1953 to either 83 or 84 , long or short bed , i got 2 off a 53 fargo 1 ton long box for my red express ,they ere alot thicker too
theres nothing as permanent as a temporary fix 70 super bee 79 red express 67 fargo 8o aspen rt
Re: Weird MoPar interchangability..... [Re: 68notch] #23492
06/20/11 07:19 PM
06/20/11 07:19 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Here are a few oldies.
1966-72 c-body, 1966-72-b-body, 1970-72 e-body 383/440 engine mounting brackets are all the same.
1973 C-body disc brakes will fit 1966-1972 c-bodies.
1966-69 b-body k-members can be replaced with 1970-74 e/1970-2 b-body k-members for cheaper suspension upgrades and better handeling. 1973-74 e-body brakes use the cheaper rotors too.
8 1/4 and 9 1/4 will fit earlier 8 3/4 rears, bolt right on.
a-body 8.75 rears and early b-body rear will fit nearly perfect in 1930's street rods (unsure what models fit with what though).
1974-80 ramcharger/traildusters came with 15x8 rims and will fit nicely on rear of mopars with 4.5 bolt pattern.
there is probably another 60 items I can post, but don't want to let the thread die off yet.
Re: Weird MoPar interchangability..... [Re: migsBIG] #23493
06/20/11 07:32 PM
06/20/11 07:32 PM
ALBERTA CANADA
CUDA8U Offline
CUDA8U  Offline
ALBERTA CANADA
THERE IS A BOOK FOR SALE ON AMAZON.COM CALLED "CHRYSLER MUSCLE CAR PARTS INTERCHANGEABILITY 1968-74" BOOK IS BY PAUL A. HERD (MOTOR BOOKS WORKSHOP)
