Driveshaft rpm sensor location on pinion yoke? #234830
02/24/09 03:08 PM
02/24/09 03:08 PM
Dallas, TX
440Brian Offline OP
440Brian  Offline OP
Dallas, TX
I'm trying to install my new data acquisiton system. The driveshaft rpm sensor mounts on the pinion yoke. I've got a 9", 1330 (long?) series OEM type yoke with a dust shield, and a Daytona support. I bought the large sensor collar (about 2.0" dia) but it won't fit. They're sending a bigger one (2.375"), but I measure about 2.5" in front of the dust shield. I'm beginning to wonder if I'm just an idiot. Am I trying to install it in the wrong place? Does the dust shield come off and reveal a spot where it can be installed? (and how do you remove the dust shield?)
Anybody else experienced this problem?
Re: Driveshaft rpm sensor location on pinion yoke? [Re: 440Brian] #234831
02/24/09 03:16 PM
02/24/09 03:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I had to make one for my 8 3/4 but this is how I did it
Re: Driveshaft rpm sensor location on pinion yoke? [Re: MR_P_BODY] #234832
02/24/09 06:19 PM
02/24/09 06:19 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I made a set up for for my dana. The yolk to housing was 3/16 and the one that fast sent me was 1/4 wide.
I had to cut off the dust seal part. With that on there wasn't any room at all.
Re: Driveshaft rpm sensor location on pinion yoke? [Re: The Shadow] #234833
02/25/09 11:13 AM
02/25/09 11:13 AM
Dallas, TX
440Brian Offline OP
440Brian  Offline OP
Dallas, TX
Thanks for the replies and pictures. I didn't realize there were so many different pinion yokes just for the 9". They make it seem like a simple bolt on process, but it sounds like that's not the case.
How hard is it to remove the dust shield without removing the yoke? Just cut it and bend/twist it off?
Re: Driveshaft rpm sensor location on pinion yoke? [Re: 440Brian] #234834
02/25/09 11:24 AM
02/25/09 11:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Its a whole lot easier to pull the yoke... and if I
remember correctly the shield is pressed on to the yoke
Re: Driveshaft rpm sensor location on pinion yoke? [Re: MR_P_BODY] #234835
02/25/09 12:45 PM
02/25/09 12:45 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I finally installed mine on the trans yoke.For me it was much easer and has worked properly.
Re: Driveshaft rpm sensor location on pinion yoke? [Re: DavidDean] #234836
06/09/09 12:46 PM
06/09/09 12:46 PM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
Anyone know where you could buy something like this? I checked around at jegs/summit and did some googleing but got no where.
1974 Roadrunner
1967 Charger
Re: Driveshaft rpm sensor location on pinion yoke? [Re: Saskabusa] #234837
06/09/09 01:19 PM
06/09/09 01:19 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Mark Williams
Re: Driveshaft rpm sensor location on pinion yoke? [Re: 440Brian] #234838
06/09/09 03:04 PM
06/09/09 03:04 PM
CHI-TOWN
REHBERGERRACING Offline
Redenbacher Racing
Redenbacher Racing
CHI-TOWN
I mounted mine on the slip yoke at the trans. Works fine.
Re: Driveshaft rpm sensor location on pinion yoke? [Re: Saskabusa] #234839
06/09/09 04:07 PM
06/09/09 04:07 PM
Dallas, TX
440Brian Offline OP
440Brian  Offline OP
Dallas, TX
Racepak Data systems has a big selection on sizes. I bought a Computech system and eventually used one of theirs. The aftermarket yoke mfr's machine them, leaving a nice straight shaft. I use a cast OEM type, which actually is tapered. I had a step cut on my yoke after removing the dust shield.
