Avs carb ported vacuum
#2348210
08/03/17 11:39 PM
08/03/17 11:39 PM
Posts: 10 Oregon
Beals
Avs on my 383. When I open the throttle, the ported vacuum creeps up slow. When I close throttle, vacuum remains.
If it were easy, everyone would do it.
Re: Avs carb ported vacuum
[Re: Beals]
#2348220
08/03/17 11:59 PM
08/03/17 11:59 PM
RapidRobert
Welcome aboard! that is a strange case. you might blast a shot of brake kleen or starting fluid into the port to clear it out as it possibly might be partly blocked. which port are you on? if you pull the vac gauge hose off of the nipple it jumps right back to zero correct? how much vacuum are we talking about?
[Re: Beals]
#2348401
08/04/17 01:02 PM
08/04/17 01:02 PM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
Deleted
[Re: TJP]
#2348435
08/04/17 02:11 PM
08/04/17 02:11 PM
Posts: 10 Oregon
Beals
The gauge works on other ports. The port will not blead down.
[Re: Beals]
#2348473
08/04/17 02:57 PM
08/04/17 02:57 PM
Posts: 15,569 Omaha Ne
TJP
Omaha Ne
The gauge works on other ports. The port will not blead down. Assuming we are talking about the port on the R(passenger side) "FRONT". Then there is something in the port that is acting like a check valve.
[Re: Beals]
#2351404
08/09/17 04:14 PM
08/09/17 04:14 PM
Posts: 10 Oregon
Beals
Pulled the carb and used a straight pin to clean the passage. Now it works. Should just rebuild the carb, or have it done.
