Re: Builders using KB Hypers?
[Re: Porter67]
#2348007
08/03/17 05:26 PM
08/03/17 05:26 PM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
On my little turd we ran the top rings at .032" on a 3.445" bore. For me hypers were great at a 150 shot, but 175 seemed to be the breaking point. I was always warned they would shatter. Never rid that, but I did break one in half. We didn't notice it untill we took the rings off and it fell apart.
[Re: Porter67]
#2348018
08/03/17 05:45 PM
08/03/17 05:45 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I have a set in a 360 that I beat like a rented mule, 4 drag weeks, lots of street miles and a good amount of passes. I do not recall what I have them gapped at but it was whatever they recommend for street/strip NA. On a good day it made 500HP according to ET and wieght.
I will say this, I had some KBs in a 340 ages ago and I broke one of them. It cracked right across the top down to the pin but didn't come apart. It just picked up massive blow by. They had been ridden hard through high school with lots of abuse and lots and lots of passes.
68 Barracuda Formula S 340
[Re: Porter67]
#2348064
08/03/17 07:10 PM
08/03/17 07:10 PM
Bad340fish
Tulsa OK
I had a nitrous addiction with a junk forged piston 360 shortblock. One of the reasons I put the hypers in my 360 was so I wouldn't do that anymore those bottles go quick and aren't cheap to fill.
[Re: Porter67]
#2348131
08/03/17 09:45 PM
08/03/17 09:45 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
They work fine for mild applications. Where they fail is not having that top ring opened up. just follow the end gap factor for the top ring, error bigger than smaller and you'll be fine. Should be around .032 I believe. Id have to consult my book to be positive.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: Porter67]
#2348273
08/04/17 01:59 AM
08/04/17 01:59 AM
Posts: 876 Missouri
jwb123
Missouri
built a 440, .590 cam, ported 906 heads, with KB pistons, raced it 6 years before it broke a rod. Follow directions on ring end gap, cylinder wall clearance, and ignition timing. The alloy of the pistons project more heat into the chamber, instead absorbing it like a cast piston, this also makes them expand less. I shifted about 6,000 rpm it ran 10.90 in a 3200lb car. Pay attention to the quench in the head, a tight quench helps stop detenation. I remember KB made a special piston for the open chamber head that you milled to adjust the quench. I would not recommend nitrous. Did build a SBC with 671 blower and KB pistons which held up well.
[Re: Porter67]
#2348424
08/04/17 01:49 PM
08/04/17 01:49 PM
Posts: 4,206 New York
polyspheric
New York
Read what KB insists on for end gap for nitrous race engine - it's bigger than you think: .0095" per inch of bore. That's .038" for a 360, .041" for 440, and .043" for 4.500" bore.
Tight ring gap is the #1 reason for hyper failure: READ THE DIRECTIONS.
Boffin Emeritus
[Re: Porter67]
#2348476
08/04/17 02:59 PM
08/04/17 02:59 PM
Porter67
https://www.uempistons.com/installation_instructions/kb_installation.pdf Thanks Poly, your correct, I think they mean that spec for full time spraying, im going by there street nitrous spec since the only track or the amount id run this is the 1/8 and never until out of low gear (oem cast crank) on a 3.95 bore. But ive got them filed at .032 but could go more, I m not putting thim in till tonight. But im open to go wider if needed.
[Re: Porter67]
#2348559
08/04/17 05:53 PM
08/04/17 05:53 PM
Posts: 216 America
WedgeFED
America
.0035" piston to wall clearance seems too loose for a hyper also...unless I'm reading op wrong
[Re: Porter67]
#2348586
08/04/17 06:58 PM
08/04/17 06:58 PM
Porter67
If you look at the link above I posted that has the KB charts they say you can go as far as .0045 https://www.uempistons.com/installation_instructions/kb_installation.pdf There is alot of info, good and bad on the KB brand hypers, I cant say this will be a learning curve for me because all I do is either stockers or strokers and this is sorta like middle ground and although different and semi fun at times im not liking some of it. Ive beat oem cast pistons in the past, broke skirts, ect but it took 60k hard street beating miles to do so, my good builds always got forged. With the pitfalls of the KB brand im wondering if it is really worth the bs in piston choice when its only a couple hundred bucks. But maybe hypers have there place in class racing?
[Re: Porter67]
#2348822
08/05/17 05:02 AM
08/05/17 05:02 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I ran them in my old 906 headed 440 that was in my 63. I used the MP .557 cam and it is a street car but I raced it about twice a year. It ran a best of 11.49 in my 3725 lb 63 and I set the ring gaps as they said which I believe was about .025 on top and .022 on second. But as stated run the proper gaps and piston to wall clearance and timing. I ran my old 440 from 2006 to 2011 and its still running good in a Duster right now. It did have a little piston slap when cold but I knew it would from the extra piston to wall clearance you run with them. Ron
