T/A & AAR Power steering pulley & Pump #234800
02/24/09 01:52 PM
02/24/09 01:52 PM
Minnesota
3twos Offline OP
3twos  Offline OP
Minnesota
Does anyone have a picture of the correct power steering pulley for the T/A cars? Also I think I have only seen the federal pumps with the oil cooler used on these cars, is that correct as well?
Al & Sheila
Re: T/A & AAR Power steering pulley & Pump [Re: 3twos] #234801
02/24/09 04:30 PM
02/24/09 04:30 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
no picture but its round, has three spokes that are kind of curvy from the center out to the ring. and they bend really easy if you try and pry them off the pump
Re: T/A & AAR Power steering pulley & Pump [Re: 3twos] #234802
02/24/09 04:38 PM
02/24/09 04:38 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The federal pump is correct and mine it the solid pulley if I remember right.
Re: T/A & AAR Power steering pulley & Pump [Re: fastmark] #234803
02/24/09 10:10 PM
02/24/09 10:10 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
This is a fast ratio box. I do not know if the std. power steering box is the same, you could get both styles on a T/A.
Re: T/A & AAR Power steering pulley & Pump [Re: Alaskan_TA] #234804
02/25/09 02:20 PM
02/25/09 02:20 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
ya, thats the one i have right there
Re: T/A & AAR Power steering pulley & Pump [Re: aarcuda] #234805
02/25/09 03:21 PM
02/25/09 03:21 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
I'm restoring an AAR and have been looking for he correct 3 spoke pulley. What all are those used on? I know the big block are different, where there several different applications for the small block? Different pumps (Federal etc) use the same 3 spoke pulley.
Re: T/A & AAR Power steering pulley & Pump [Re: 6pkaar] #234806
02/25/09 03:32 PM
02/25/09 03:32 PM
Minnesota
3twos Offline OP
3twos  Offline OP
Minnesota
I would almost be guessing that the fan type pulley was used due to the power steering fluid cooler used on these cars but that is a guess. I know where you can get a whole pump,pulley and cooler if you are interested send me a pm
Al & Sheila
Re: T/A & AAR Power steering pulley & Pump [Re: 3twos] #234807
03/01/09 04:03 PM
03/01/09 04:03 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
I've seen most all 340 cars get the 3 spoke and the 318 cars get the solid pulley
Re: T/A & AAR Power steering pulley & Pump [Re: Steve340] #234808
03/02/09 11:27 PM
03/02/09 11:27 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
Isn't the type of pulley dependent on which pump it is? I have had several cars that have had the solid pulley and they were all Federal pumps. The cars I have had with the pulley that has the three spokes have all been Saginaw pumps (both big and small block).
Re: T/A & AAR Power steering pulley & Pump [Re: 6PAX] #234809
03/03/09 10:17 PM
03/03/09 10:17 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
If you look at the picture above, it is a Federal pump with the press on 3 spoke pulley.
Re: T/A & AAR Power steering pulley & Pump [Re: Alaskan_TA] #234810
03/04/09 12:03 AM
03/04/09 12:03 AM
Minnesota
3twos Offline OP
3twos  Offline OP
Minnesota
Barry,
Are you saying you could get both pumps on the t/a cars? I think I have only seen federal pumps on them. Also is it correct that some t/a cars had power steering with fast ratio steering box, some had manual steering and some had just regular power steering without the fast ratio box?
Al & Sheila
Re: T/A & AAR Power steering pulley & Pump [Re: 3twos] #234811
03/04/09 12:19 AM
03/04/09 12:19 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Barry,
I meant Fast Ratio & the Std. Ratio power boxes.
T/As came with either of those two or manual steering.
AARs came with the manual box or the Fast Ratio Power box. I have not seen an AAR yet with a std. ratio power box.
Edit;
Just to clarify that a little further, when I say "I have not seen an AAR yet with a std. ratio power box", I am talking about seeing it on an AAR broadcast sheet, not on the car itself.
