Re: Thickness of main girdle
[Re: hemienvy]
#2347962
08/03/17 03:59 PM
08/03/17 03:59 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Just have some kickouts welded in the pan but you could have some bar stock welded to make a spacer.My dragster styl girdle is only 3/8"
[Re: hemienvy]
#2348417
08/04/17 01:39 PM
08/04/17 01:39 PM
Posts: 4,213 New York
polyspheric
New York
Increasing pan capacity to achieve what? It might keep the pickup covered a bit more (especially with no baffles), if the pickup is lowered by the same amount. The oil temperature won't change much. Getting the oil away from the crank might be better than adding oil. What other oil control do you have in the pan now?
Boffin Emeritus
