Re: RB Intake Manifold and EFI (TBI) [Re: ChrgrCuda] #2346523
08/01/17 01:27 AM
08/01/17 01:27 AM
AndyF Offline
AndyF  Offline
Here is a picture of the ProFlo that I had for a while. (sold it on Moparts to a member)
I don't have a ruler in the picture but you can kind of figure out how tall it is by looking at the other parts on the engine. I think the Pro Flo is roughly the same height as a Victor intake plus a carb. So you are saving a couple of inches that the air cleaner usually takes up.
The hassle is the throttle body clearance around the thermostat housing and upper radiator hose and all of that stuff. I'm sure people have figured it out but I haven't seen a lot of pictures posted. There is at least one Moparts member who has a Pro Flo in his E body. I remember seeing pictures of it before and it looked really clean.
The good news is if you go CNP you can ditch the distributor and use one of my cam sync units. That eliminates a bunch of interference issues with the throttle body and the distributor and cleans up the front of the engine.
Re: RB Intake Manifold and EFI (TBI) [Re: ChrgrCuda] #2346540
08/01/17 02:33 AM
08/01/17 02:33 AM
Texas, USA
ChrgrCuda Offline OP
Texas, USA
Dam. That's super slick. If I'd known that would possibly fit under my stock hood I'd gone with this setup. Those runners look to be a straight shot to the valves. Can it be opened up to Max Wedge ports?
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: RB Intake Manifold and EFI (TBI) [Re: ChrgrCuda] #2346542
08/01/17 02:42 AM
08/01/17 02:42 AM
AndyF Offline
AndyF  Offline
You would need to add weld material to the outside of the runners to make it big enough to work on a Max Wedge. The Pro Flo has really tiny ports out of the box. More show than go. I bet they work great once they are ported but I've never run one.
Re: RB Intake Manifold and EFI (TBI) [Re: ChrgrCuda] #2346549
08/01/17 03:16 AM
08/01/17 03:16 AM
Texas, USA
Texas, USA
Thanks Andy. After I receive my 337 intake from Summit I'll be sending it off to Wilson for the Max Wedge port work and having the bosses drilled for the injectors. I've been in contact with Rich and will be ordering the FAST XFI system thereafter. Thanks for the outstanding information from you and Rich.
Re: RB Intake Manifold and EFI (TBI) [Re: ChrgrCuda] #2346641
08/01/17 12:41 PM
08/01/17 12:41 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The throttle body fits with a 90 on the water neck. Here's a CNP 440 using that manifold. It fits under a flat hood.
Re: RB Intake Manifold and EFI (TBI) [Re: Mopar_Rich] #2346744
08/01/17 03:58 PM
08/01/17 03:58 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
I've had both the Victor and Pro-Flo on my 493 in the Charger. The Victor with throttle body fits under the hood but I had to build a custom air cleaner. It worked but the intake air temp was quite high so I changed up to the Pro-Flo and CNP. Air intake was moved in front of the rad and reduced the intake charge temperature dramatically. I didn't find any real difference in performance but as stated, the Pro-Flo has small runners.
Re: RB Intake Manifold and EFI (TBI) [Re: ChrgrCuda] #2346867
08/01/17 08:17 PM
08/01/17 08:17 PM
AndyF Offline
AndyF  Offline
Looks good with the coils mounted on the side of the intake. Nice looking engine with the Pro Flo on there.
Re: RB Intake Manifold and EFI (TBI) [Re: ChrgrCuda] #2346983
08/01/17 10:59 PM
08/01/17 10:59 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I wanted a proflow but it only supports a 90mm TB. So ill be doing a elbow and hiding the coils down low beside the block.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: RB Intake Manifold and EFI (TBI) [Re: ChrgrCuda] #2347684
08/03/17 01:48 AM
08/03/17 01:48 AM
Texas, USA
Texas, USA
The 337 intake must be pretty popular. Summit revised the ship date from 8/4 to 8/14. Also went up on the price from about $250 to $377.
Re: RB Intake Manifold and EFI (TBI) [Re: ChrgrCuda] #2347839
08/03/17 01:20 PM
08/03/17 01:20 PM
AndyF Offline
AndyF  Offline
I'll be interested to see if you actually get an intake from Summit. They might just keep revising the ship date out..........
I don't think it is Summit's fault, Mopar Performance probably lies to them. I think MP waits until they have a bunch of backorders and then they ask the foundry to cast some intakes. So depending on where you are in line you might get an intake right away or it might take months.
I know a guy who grabbed several of those intake last time they were physically available so they do actually appear from time to time but I do not have any insight on when they will appear next. Hopefully you'll get yours right away. They are a really good intake once you get your hands on them.
Re: RB Intake Manifold and EFI (TBI) [Re: AndyF] #2347843
08/03/17 01:27 PM
08/03/17 01:27 PM
Texas, USA
Texas, USA
Thanks Andy. If they revise them again I'll cancel my order and look hard at the Edelbrock pro flow intake.
Re: RB Intake Manifold and EFI (TBI) [Re: ChrgrCuda] #2347851
08/03/17 01:38 PM
08/03/17 01:38 PM
central il.
second 70 Online content
second 70  Online Content
central il.
Might be in luck Summit site now says ships tomorrow.
