Re: Aluminum wedge block
[Re: moparmafia]
#2347501
08/02/17 10:05 PM
08/02/17 10:05 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Just check around. Here, Yellow Bullet, ForAbodiesonly, forBbodiesonly, forEbodiesonly, Facebook. I got mine off of Racing Junk. Cheap, but needs sleeves. I can deal with that.
[image][/image]
[Re: moparmafia]
#2347553
08/02/17 11:03 PM
08/02/17 11:03 PM
Superfreak
Superfreak
[Re: ]
#2347556
08/02/17 11:07 PM
08/02/17 11:07 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
They are around but guys want them for nothing or hesitate and if the price is right they go fast.
[Re: moparmafia]
#2347698
08/03/17 03:03 AM
08/03/17 03:03 AM
Posts: 43,285 Bend,OR USA
Cab_Burge
Why do you want aluminum?
[Re: moparmafia]
#2347867
08/03/17 02:01 PM
08/03/17 02:01 PM
Posts: 289 Lowes
steve660
Lowes
I have an iron World wedge block that needs all 8 sleeved. Prob going to sell it, just havent listed it yet. Has 4.600 bore. Thats why it needs sleeved. #8 has hair line crack. So i figure all 8 need sleeved.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: Dragula]
#2347870
08/03/17 02:06 PM
08/03/17 02:06 PM
Posts: 568 Ky
moparmafia
Ky
Why do you want aluminum? Why wouldn't you want aluminum? If I could afford it, all my engines would be aluminum. I want the weight loss and the ability to repair. I am going to run a f2 procharger and i would rather not use the old iron blocks.
[Re: moparmafia]
#2348001
08/03/17 05:14 PM
08/03/17 05:14 PM
Cab_Burge
Why do you want aluminum? Why wouldn't you want aluminum? If I could afford it, all my engines would be aluminum. I want the weight loss and the ability to repair. I am going to run a f2 procharger and i would rather not use the old iron blocks. I'm glad you did your research on this before making your decision Good luck on finding a used block I talked to Tim Banning at FHO last week about a new KB low deck aluminum street wedge block (no wet sleeves) for one of my local customers, he said they will make them soon but they ain't cheap I assembled a KB street hemi dry sleeve block(#55, I think) for a blower on the street for a customer years ago when Mopar sold them through their dealer network, it work good once we got the EFI problems sorted and tune up correctly
[Re: moparmafia]
#2348012
08/03/17 05:33 PM
08/03/17 05:33 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Well a few observations. I basically prefer aluminum all the time these days, reparability is a part of it but for me weight is the main reason. I think we make a bit of power but I no way believe that the loss of power, if any is made up but the weight savings. Give me the 165-175lbs less weight any day.
The heads up car is also an ALUMINUM block and being a SB Chebbie the choices are endless. The aluminum block was chosen for the same reason. Weight savings.
As for Mopar blocks, they are out there to be certain. When you see one you need to be ready to act. Another thing is on some(indy)if they need sleeves it can get expensive to purchase and have them installed. Not a lot of places will do sleeves in those blocks. Also beware of a block with zero history. At a point aluminum gets "soft" through heat cycles. No different than aluminum rods. I have purchased a few over the years and been bitten once by "soft" material.
[Re: Cab_Burge]
#2348661
08/04/17 09:13 PM
08/04/17 09:13 PM
Posts: 5,080 organ
maximum entropy
organ
What type of blocks do all the Pro Stock team use
they use iron because it's in the rule book.
[Re: maximum entropy]
#2348769
08/05/17 01:14 AM
08/05/17 01:14 AM
Cab_Burge
Carl, NHRA tech and the Pro stock team owners and drivers have a rule changing meeting at the end of each year to decide what and how they will change the rules for the next year. They could have had aluminum blocks years ago but most of the teams like Compact Graphite Iron blocks better I wonder what type of blocks NASCAR cup teams use
[Re: moparmafia]
#2348920
08/05/17 12:49 PM
08/05/17 12:49 PM
Al_Alguire
Las Vegas
Last I checked not many here are chasing ever last little HP..Trust me aluminum is the way to go unless you are one of those Comp, Pro Stock or Nascar guys on here...
[Re: moparmafia]
#2349081
08/05/17 05:38 PM
08/05/17 05:38 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
I want to boost the bajeezers out of one! lol
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: moparmafia]
#2349095
08/05/17 06:15 PM
08/05/17 06:15 PM
Posts: 4,210 New York
polyspheric
New York
Current LSX development suggests that aluminum moves around more than you want at really high power, and that the smallest bore size thickest wall) doesn't hurt much at high boost.
Boffin Emeritus
