Page 5 of 5 1 2 3 4 5
Re: Bought my first 400 Block this Weekend [Re: Thumperdart] #2377741
09/27/17 03:08 PM
09/27/17 03:08 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Originally Posted By Thumperdart
Detination is a killer weather n/a, boost or NOS...............
So does taking them to the drag strip every weekend and beating the snot out of it. Nothing compairs to that test
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Bought my first 400 Block this Weekend [Re: pittsburghracer] #2377778
09/27/17 04:14 PM
09/27/17 04:14 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I beat my car on the street more than anyone on here races I guarantee it..............Hundreds of miles and many carbs tested on a weekly basis so, not the case........... drive
Re: Bought my first 400 Block this Weekend [Re: Cab_Burge] #2377854
09/27/17 06:31 PM
09/27/17 06:31 PM
1.5 miles west of Jacksonburg ...
Ohio Joe Offline
Ohio Joe  Offline
This motor was 512 ci, n/a on e-85. B-1 heads , 13 to 1 compression alum rods and main caps . This is the only pic have to show, wish I could show the front of the block around the timing chain area were you can see the cracks there also. Block was part filled.
66 Dart GT " Rat Racer"
Re: Bought my first 400 Block this Weekend [Re: Ohio Joe] #2378121
09/28/17 02:35 AM
09/28/17 02:35 AM
Thanks for sharing that inforamtion up
My current bracket motor is similar, 4.35 bore with 4.25 stroke, 6.700 RPM BB Chevy type H beam steel rods with Diamond custom pistons with around 14.0 to one now with a set of Victor Max Wedge heads on E85. Early cold weather 400 block from AndyF (Many Thanks up bow) with 440 Source aluminum main caps and studs, hopefully it won't end up looking like yours luck Not filled either work
Did it fail during run? If so I hope nobody and nothing else got hurt luck
I have broke parts on a run and thought I was going to bend up some sheet metal several times, thanks to God I didn't get hurt or bend the cars boogie
Re: Bought my first 400 Block this Weekend [Re: Cab_Burge] #2378546
09/28/17 11:27 PM
09/28/17 11:27 PM
Ohio Joe Offline
Ohio Joe  Offline
According to the data logger about 2seconds into the run it let go. My son said it just shook real hard and he reached up and shut it down . After seeing what it did it's hard to believe it was still running when he shut it off. He says he is lucky it happened early in the run.
Re: Bought my first 400 Block this Weekend [Re: Ohio Joe] #2378592
09/29/17 12:25 AM
09/29/17 12:25 AM
I'm glad it didn't hurt him or the car up
I've had a couple of motors let go in the 1/4 mile past the 1000 clocks, not good shock
Re: Bought my first 400 Block this Weekend [Re: Cab_Burge] #2379048
09/29/17 09:04 PM
09/29/17 09:04 PM
Ohio Joe Offline
Ohio Joe  Offline
Thank God for the diaper, it has probably saved his butt twice.
