Re: Real world weight loss program and it` cost..........
[Re: hemi-itis]
#2350272
08/07/17 07:56 PM
08/07/17 07:56 PM
Posts: 1,453 N.W. INDIANA
moparjohn
N.W. INDIANA
I have been gone for a while but the weight loss program is ALWAYS in action. I have 2 things to report on. The first item is the steering column on my 1970 GTX. The GTX was a automatic on the floor car. I have removed all that and run a aftermarket shifter with a cable. The GTX had linkage to lock the steering wheel when in park with the key in the lock position. There is a tube that runs through the steering column to do this. Since I'm not using this I removed the locking tube and the surround. This amounted to 3LBS of weight loss! I have attached a picture that shows the tube at the bottom. The second item is the driver. My wife has been working on losing some weight and it has affected me and I have lost 5 more pounds. Yesterday at Route 66 Raceway the GTX with me, fuel and safety equipment scaled in at 3065LBS! We had a great outing and lost in the 5th round. MJ
[Re: moparjohn]
#2350492
08/08/17 02:12 AM
08/08/17 02:12 AM
fullmetaljacket
Great trick-notion to remove the steering lock tube. that's a good place to shave weight off the car. Personal weight is always good to shed unless you drive a Funny car where your weight is in the middle and rearward.
[Re: fullmetaljacket]
#2350497
08/08/17 02:29 AM
08/08/17 02:29 AM
fullmetaljacket
