Slicks on a 7" wide rim
#234608
02/24/09 11:12 AM
02/24/09 11:12 AM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
Suppose you HAD to run a 7" wide rim, what size slick could you run? 9"? Something like a 29x9.0-15?
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
Re: Slicks on a 7" wide rim
[Re: BBR]
#234609
02/24/09 11:22 AM
02/24/09 11:22 AM
Posts: 507 Illinois
Hurst390
Illinois
I wouldn't..It would not take long to use up the center of a wider tire on such a narrow rim...I ran some firestone 26x7 slicks on a 6or7"rim in my SC/Rambler with a 4-speed..left at 7k..ran mid 11's with that car..
80 AMX Barry Allen 420 AMC Iron Heads Jerico 4-speed Advanced clutch 2950# street legal
5.97 115.73 Coles county dragway 10/28/07
9.42 142.96 best in 08(6.00 115.8 1/8)
5.97 116.2 in 09
http://www.youtube.com/watch?v=AXSr201-tmA
[Re: BBR]
#234610
02/24/09 11:40 AM
02/24/09 11:40 AM
Posts: 2,936 Richmond, VA
VT_Dart
Richmond, VA
Depending on the actual tire, I think you could get away with a 9". I ran a 10.5" Sportsman Pro on a 7" rim and, although it was way too wide a tire, it still technically worked and hooked pretty well with the right pressure. It actually didn't wear nearly as bad as I thought it would either.
Darrah Heath
[Re: BBR]
#234612
02/24/09 04:37 PM
02/24/09 04:37 PM
Posts: 535 Ohio
racerAL
Ohio
I run 15x7 cop wheels with a 30x9 Hoosier slick..as stated earlier you will have un-even slick wear...i have 42 passes on mine and they are starting to wear in the center..you didn't say how fast you were going to go or how heavy of a car you are runnin,that will have an effect on how fast the slick wears.If you are going to be slower than 12.50's or so ,i would say that you would get avg. life out of the slick. ...I don't have a very good pic of my car with just the wheel and slick ,but this one willl show you how they look... [image] [/image]
[Re: racerAL]
#234613
02/24/09 06:43 PM
02/24/09 06:43 PM
BBR
Amarillo, Texas
That's the money shot! Thanks!
It is about 2900lbs hopefully running 10.90's, but will probably 60' pretty fairly lousy.
[Re: KOS]
#234616
02/24/09 07:51 PM
02/24/09 07:51 PM
Posts: 535 Ohio
racerAL
Ohio
KOS..if you don't mind i have a few ? about runnin that fast on that size slick....first off, do you run tubes and secondly what air pressure do you usually run...I'am wondering now if i'am running to much pressure...
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
[Re: racerAL]
#234618
02/24/09 10:32 PM
02/24/09 10:32 PM
KOS
with the slicks i tried both ways with and without tubes at 14.5-15lbs of air pressure either way.no noticable difference in performance maybe a tiny bit more stable up top with the tubes.with the DRs no tubes 18lbs of air press.
