Slicks on a 7" wide rim #234608
02/24/09 11:12 AM
02/24/09 11:12 AM
Amarillo, Texas
BBR Offline OP
BBR  Offline OP
Amarillo, Texas
Suppose you HAD to run a 7" wide rim, what size slick could you run? 9"?
Something like a 29x9.0-15?
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Slicks on a 7" wide rim [Re: BBR] #234609
02/24/09 11:22 AM
02/24/09 11:22 AM
Illinois
Hurst390 Offline
Hurst390  Offline
Illinois
I wouldn't..It would not take long to use up the center of a wider tire on such a narrow rim...I ran some firestone 26x7 slicks on a 6or7"rim in my SC/Rambler with a 4-speed..left at 7k..ran mid 11's with that car..
80 AMX Barry Allen 420 AMC Iron Heads Jerico 4-speed Advanced clutch 2950# street legal 5.97 115.73 Coles county dragway 10/28/07 9.42 142.96 best in 08(6.00 115.8 1/8) 5.97 116.2 in 09 http://www.youtube.com/watch?v=AXSr201-tmA
Re: Slicks on a 7" wide rim [Re: BBR] #234610
02/24/09 11:40 AM
02/24/09 11:40 AM
Richmond, VA
VT_Dart Offline
VT_Dart  Offline
Richmond, VA
Depending on the actual tire, I think you could get away with a 9". I ran a 10.5" Sportsman Pro on a 7" rim and, although it was way too wide a tire, it still technically worked and hooked pretty well with the right pressure. It actually didn't wear nearly as bad as I thought it would either.
Darrah Heath
Re: Slicks on a 7" wide rim [Re: BBR] #234611
02/24/09 01:21 PM
02/24/09 01:21 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I used to run an H&H Race Master G60/15 (8.2" x 26") on
15" x 7" steel wheels on my 71 Duster.
I'd say they fit perfectly. I wish I had pictures of that car.
Re: Slicks on a 7" wide rim [Re: BBR] #234612
02/24/09 04:37 PM
02/24/09 04:37 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
I run 15x7 cop wheels with a 30x9 Hoosier slick..as stated earlier you will have un-even slick wear...i have 42 passes on mine and they are starting to wear in the center..you didn't say how fast you were going to go or how heavy of a car you are runnin,that will have an effect on how fast the slick wears.If you are going to be slower than 12.50's or so ,i would say that you would get avg. life out of the slick. ...I don't have a very good pic of my car with just the wheel and slick ,but this one willl show you how they look... [image][/image]
Re: Slicks on a 7" wide rim [Re: racerAL] #234613
02/24/09 06:43 PM
02/24/09 06:43 PM
Amarillo, Texas
BBR Offline OP
BBR  Offline OP
Amarillo, Texas
That's the money shot! Thanks!
It is about 2900lbs hopefully running 10.90's, but will probably 60' pretty fairly lousy.
RMRW 2018
RMRW 2020
Re: Slicks on a 7" wide rim [Re: BBR] #234614
02/24/09 07:06 PM
02/24/09 07:06 PM
Tucson, Arizona
johnnyrotten Offline
Tucson, Arizona
I have been running 29.5x10.5x15 Mickey Thompson ET drags on a 7" wheel for years with no problems at all. I get a good contact patch and even wear across the entire tread. I wore the last set to the cords and they showed the even wear very well!! I would have liked to run a wider wheel, but a stock wheelwell, stock spring location, and no money prevented it from happening. I would think a 29x9 would work fine, even a 28x9. It may not be optimum, but with tire pressue adjustments you should have good results.
Re: Slicks on a 7" wide rim [Re: BBR] #234615
02/24/09 07:10 PM
02/24/09 07:10 PM
K
KOS Offline
KOS  Offline
K
ive ran 29x9 and 28x9slicks and now 275/60DR(28x9)on a 7"rim running 9.7s @137mph and mid 1.3 60fts with no problems whatsoever.
Re: Slicks on a 7" wide rim [Re: KOS] #234616
02/24/09 07:51 PM
02/24/09 07:51 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
KOS..if you don't mind i have a few ? about runnin that fast on that size slick....first off, do you run tubes and secondly what air pressure do you usually run...I'am wondering now if i'am running to much pressure...
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: Slicks on a 7" wide rim [Re: racerAL] #234617
02/24/09 09:25 PM
02/24/09 09:25 PM
north west LA
W
W2DODGE Offline
W2DODGE  Offline
W
north west LA
I have run Goodyear 28 and 29x9 and M/T 28x9 on 7" rims under my dart down to 1.461 60' 6.61 @ 104 MPH 1/8th the centers will wear a bit but by the end of a season Feb - Nov racing test and tune 2 to 3 days a week the sidewalls go before the tread
Re: Slicks on a 7" wide rim [Re: racerAL] #234618
02/24/09 10:32 PM
02/24/09 10:32 PM
K
KOS Offline
KOS  Offline
K
with the slicks i tried both ways with and without tubes at 14.5-15lbs of air pressure either way.no noticable difference in performance maybe a tiny bit more stable up top with the tubes.with the DRs no tubes 18lbs of air press.
