Re: Starting to work on the Duster
[Re: AndyF]
#2342599
07/24/17 05:38 PM
07/24/17 05:38 PM
Posts: 570 UK
rb446
UK
Yep your gonna have to slow that down by around .5 sec to get into the 10's
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: AndyF]
#2342663
07/24/17 07:32 PM
07/24/17 07:32 PM
Posts: 8,818 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
I was really, really, REALLY tempted but don't have the room without infringing on some friends shop space. When you took the ad down, I thought "Good, the temptation is gone". Gutted or no, seems like a good deal for $4900!
How come the windshield bars are cut? Just curious... The guy that did the cage screwed up the front bars and made the car really difficult to work on. They were too far back and got in the way of everything. It was kind of the last straw for the guy who sold the car to me. He had saved up his money to build a race car but the guy who did the cage ruined the car. So his money was gone and his car was worse off than before. He just gave up and sold out. I'll have to fix the bar somehow. I haven't figured it all out yet but I think I can cut off the front bars and just run the rear 6 point cage and be legal at 10 seconds. I need to research it a bit more to know for sure. Worst case is the entire cage needs to meet the whiz wheel and I start over with a new 6 point setup. I do not intend to make it 9 second legal. Just like mine, 10.80s no quicker. Cut out the halo and front down bars. Do you have X side bars? I tied the front frame bar into those. If tens are doable then the down bars can always be put in rather easily. Can you really tell the difference between a 10.20 and a 9.70? Keep it slow and fun to get in and out of, no net, no cert.
[Re: roadhazard]
#2342667
07/24/17 07:35 PM
07/24/17 07:35 PM
Posts: 31,259 Oregon
AndyF
An honest 700 HP @ 3,000# You may as well put the 10 point in and get it over with.... Yeah but I'm sure the 727 and Dana 60 are going to suck up a bunch of power and the 700 hp was with cold air for the carb and dyno headers dumping into a very low restriction muffler system. I also plan on driving the car to the track so that means street legal rear tires and the front suspension has to be up in the air a bit more than a pure drag car. But yeah, if it ends up around 3000 lbs wet with driver even 600 hp will push it right to the 10.00 line. The car has 4.56 gears with 345/55-15 tires so it will go thru the lights at around 135 mph at 7000 rpm. Should be a fun ride if it all works out. We dyno tested the engine to 7000 rpm so it will pull it. The peak power was around 6800 rpm so it should pull to the stripe. Guess some of it depends on how good the converter is. I don't know much about torque converter so I'll have to study up on them.
[Re: AndyF]
#2342915
07/25/17 04:56 AM
07/25/17 04:56 AM
Posts: 20,387 Park Forest, IL
slantzilla
Park Forest, IL
You just can't go wrong with a Duster.
[Re: AndyF]
#2342925
07/25/17 06:11 AM
07/25/17 06:11 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
I'm just going to put it together enough to get it running. It will be very unfinished when I'm finished with it! Sounds like every project car I've ever owned!!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: DusterKid]
#2343195
07/25/17 05:20 PM
07/25/17 05:20 PM
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
One thing to remember about a roll bar vs roll cage is tubing diameter. With a 6 pt bar the bars (atleast the main hoop) is required to be larger in diameter than if you have a entire cage. I forget the actual tubing size, but if the cage was a kit for a 10 pt cage than cutting out the bars may not make the 6 pt portion legal. Might be wrong, don't have rule book in hand right now. Mild steel 1-5/8 x.120 dom, CM .083 x 1-5/8, welded seam type 1-3/4 x .134 wall. Side bars, if X, then 1-1/2 x .065, if single, same as hoop, seat bar 1/14 x .065
