Re: Rear seat install in '68 Coronet - dumb question...
[Re: lockjaw-express]
#2345542
07/30/17 01:47 AM
07/30/17 01:47 AM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
the back 1st, then put the bottom in , sit on a little stool outside the open door & use you foot & push back & down with leg,foot on the lower front of the seat
#2345543
07/30/17 01:48 AM
07/30/17 01:48 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Yes, the seat back gets hung first. I usually remove the front seat(s) first. Makes access easier Then bolt the bottom of it down. Then the bottom gets pushed in under it. Might take a few tries to get the hooks to grab.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#2345544
07/30/17 01:50 AM
07/30/17 01:50 AM
CSK
Pattison Texas
Yes, the seat back gets hung first. Then bolt the bottom of it down. Then the bottom gets pushed in under it. Might take a few tries to get the hooks to grab. no bolts, has flat blades that goes through a loop at the lower corners
[Re: CSK]
#2345545
07/30/17 01:52 AM
07/30/17 01:52 AM
bboogieart
Lost and Spaced
Ha ha. First you treed me then corrected me while I was editing my post... You are of course correct.
#2345569
07/30/17 05:32 AM
07/30/17 05:32 AM
Posts: 562 Ohio
lockjaw-express
Ohio
Thanks guys...I have been having one heck of a time trying to get the seat bottom in! Jeeze!
Cussing and swearing has not helped either.
Mark
#2345798
07/30/17 05:37 PM
07/30/17 05:37 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Yeah they can be a real pain to install sometimes.Same with getting them to release.Sometimes they just come right out other times it takes some swearing.Rocky
Chrysler Firepower
