Upper control arm bushing sleeves. Can I skip them?
#2345306
07/29/17 03:37 PM
07/29/17 03:37 PM
Posts: 1,307 BC, Canada
Black_Bee
BC, Canada
Hey guys
I'm currently replacing the upper control arms on my '69 Super Bee. The car is lowered and I've had a tire wearing issue so I pulled the upper arms to install some Moog offset bushings before taking it for an alignment.
One of the arms had a small rust hole, and one of the bushing sleeves was nearly cut in two when the bushing was previously replaced (to remove the outer shell I guess), and while the sleeve was very tight previously, the sleeve no longer fits tight.
I couldn't find another arm locally, so I purchased a pair of new upper control arms (they are shockingly inexpensive), but they didn't come with the sleeves on the bushings like my stock ones had.
I've read that these sleeves didn't come on all cars, so my question(s) is... with these new arms, can I simply skip installing the sleeves on the bushings? I could possibly use this cut one, but it fits very loose on the bushing. What was the purpose of this sleeve?
Thanks!
Paul '69 Super Bee 383 EFI Turbo
Re: Upper control arm bushing sleeves. Can I skip them?
[Re: 1969ronnie]
#2345341
07/29/17 05:09 PM
07/29/17 05:09 PM
Black_Bee
BC, Canada
in the parts book section 2-08-11 arm locking sleeve part # 1857 840 . they do make aftermarket sleeves. I cant seem to find anybody that makes them... I've checked the usual places (mancini, rock auto, summit, ebay, amazon, etc) , but who knows what each place might call these things. Thanks for your help guys... its not a dedicated show car, but I might have no choice but to skip using at least one of these things. I wonder if putting the loose one on loose would be better than nothing? Maybe tighten it up with some pliers? Thanks again!
[Re: Black_Bee]
#2345375
07/29/17 06:38 PM
07/29/17 06:38 PM
Posts: 2,386 White Plains, NY
VCODE
White Plains, NY
Try Scott Smith, he did have them Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: Black_Bee]
#2345464
07/29/17 10:37 PM
07/29/17 10:37 PM
Black_Bee
BC, Canada
I hit up the local hardware store and found some pipe that ended up having an inside diameter that was close enough, and I was able to make it work.
Thanks again!
[Re: Big_E]
#2345738
07/30/17 03:24 PM
07/30/17 03:24 PM
Black_Bee
BC, Canada
Did you get them pressed on yet? They should be a little hard to get on like when you pressed in your bushings. Yes... I pushed them on with the same tool that I used to remove and install the bushings, a ball joint press. Thanks!
