440 source heads #2344564
07/27/17 10:25 PM
07/27/17 10:25 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Anyone tried the stealth or super stealth heads from 440 Source ?
What kind of power can be made with those ?
Dan
Re: 440 source heads [Re: Wedgeman] #2344599
07/27/17 11:11 PM
07/27/17 11:11 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I have them on my street strip 440. No problems with them. Changed the springs/locks/retainers over to Comp Cams products. Had to enlarge pushrod holes for pushrods,2 shops checked them over and found no problem with them at all.Standard Stealth heads.
Nautilus Racing-
Re: 440 source heads [Re: Wedgeman] #2344607
07/27/17 11:23 PM
07/27/17 11:23 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
had stock Stealths , were great . Now have CNC version - even better
Tex
New best ET 10.259@129.65 .
New best MPH 130.94
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 440 source heads [Re: Wedgeman] #2344615
07/27/17 11:38 PM
07/27/17 11:38 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have the super stealths, they take .650 special offset intake rocker, they need a LOT of work to make them flow 330ish CFM @ .700 lift, my car runs good, but there are much better heads out there, if I was to do it over I would get the Trick Flow 240 for my application. My car is not a max effort build, it is a street strip car, so far with traction problems, no tuning yet, 12.03 @ 116 MPH 1/4 spinning, 4100 lb with 3000 ft DA , 512 low deck small solid FT cam, .576 ,248 @ .050 9.5-1 comp.
Re: 440 source heads [Re: CSK] #2344650
07/28/17 12:39 AM
07/28/17 12:39 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Did a low compression 440 with Stealths replacing 452's. Fun little ride until I grenaded the 440.
Took those heads, sent them off to Modern Cylinder Head for CNC port, and slipped them on a 505" stroker shortblock.
They did have new (not Source) locks and retainers installed by a local machine shop when I bought them.
Very mild hydraulic Howards roller and 3.54 gears.
Best of 11.19 @ 121mph with 60 ft. still needing work in 3,600 lbs. with driver.
4,000 street miles and tons of dragstrip passes in last two seasons.
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: 440 source heads [Re: GY3] #2344651
07/28/17 12:44 AM
07/28/17 12:44 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Flow 267 on my bench out of the box and go 300cfm easily with some loving care.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: 440 source heads [Re: Wedgeman] #2344652
07/28/17 12:51 AM
07/28/17 12:51 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Miles away from the Edelbrock
stuff !!
Re: 440 source heads [Re: Wedgeman] #2344656
07/28/17 12:59 AM
07/28/17 12:59 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
stuff !!
do the Edelbrock flow what they claim ? my Super Stealth out of the box flowed the same as the stealth OTB, 267,on my bench, same as Pittsburghracer's #'s
Re: 440 source heads [Re: Wedgeman] #2344666
07/28/17 01:22 AM
07/28/17 01:22 AM
I have a 4.150 stroke 440 block stroker motor with a set of 440 Source CNC ported heads in my shop now that broke a exhaust valve guide bottom off and drop some of the debris into the combustion chamber shock NOT GOOD down
The same customer had another different bracket motor that he broke a exhaust valve off a new set of the non ported 440 Source heads in the water box doing a uncontrolled burn out so keep that in mind work
There are some people who can screw up a 5 ton wrecking ball in a sand box with no tools, other than themselves whistling grin
Re: 440 source heads [Re: Wedgeman] #2344717
07/28/17 08:23 AM
07/28/17 08:23 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I bought a set back in 08'. I upgraded to 10 degree keepers and ran them for a few years than changed the springs and had some port work done on them. There are a decent head for the price if your looking to save weight, but if it is a race head I'd consider Trick Flows as they seem to be a better bang for the buck.
Re: 440 source heads [Re: Wedgeman] #2344722
07/28/17 08:41 AM
07/28/17 08:41 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
After living through 3 cracked Stealth heads within 2 years (one lasted 3 or so passes), a fabbed oil pan that didn't fit, or a fabbed timing chain cover that was 1/8" off, I avoid them for pretty much everything. You get what you pay for...better quality options out there for a lil more coin. Pay now or pay later.
Only benefit I can see using their Stealth head is they somewhat resemble a stock iron head when they're painted, at a quick glance.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 440 source heads [Re: Wedgeman] #2344724
07/28/17 08:44 AM
07/28/17 08:44 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Dan
Stealths have basically the same POTENTIAL as Edelbrock Performer RPM, since they are the same ports & chamber wrapped in an OEM-style casting. It comes down to what level of work is done to them.
Re: 440 source heads [Re: Wedgeman] #2344746
07/28/17 10:03 AM
07/28/17 10:03 AM
Idaho
LaRoy Engines Offline
Idaho
Stealths are a step-up stock replacement head. As said above, they have the same potential as the RPM head. A basically stock but prepped Stealth head on a mild 440 can make 510-520 HP. A very well ported (very expensive!) Stealth set of heads can make 750 HP. If you intend to race, buy another head.
Re: 440 source heads [Re: Wedgeman] #2344771
07/28/17 11:09 AM
07/28/17 11:09 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
For $89 more..... I'd just get some E Street heads.
In fact...... That's exactly what I did.
For me, the Stealth head is a budget head for those who really want/need the straight plugs, and/or the OE type appearance.
Between the RPM/Stealth/Sidewinder heads, I find the Stealth has the weakest exhaust port....... And the Sidewinder is the easiest to get to 300cfm on the intake side(IMO, it has the best short turn of the 3).
The RPM/E street is American made(a plus to me), and has quite a bit more room around the intake pushrods, so 3/8" pushrods and 1.5 rockers usually fit without any clearancing.
Re: 440 source heads [Re: Wedgeman] #2344988
07/28/17 07:25 PM
07/28/17 07:25 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Ok Thanks
Dan
Re: 440 source heads [Re: Wedgeman] #2344995
07/28/17 07:35 PM
07/28/17 07:35 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Is the MP 452 head still out there? Like an Edelbrock RPM with straight plugs?
Re: 440 source heads [Re: bobby66] #2348428
08/04/17 01:02 PM
08/04/17 01:02 PM
Granbury TX
Prochargedmopar Offline
Granbury TX
Stealth head porting results from flow tech today.
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Re: 440 source heads [Re: Prochargedmopar] #2348468
08/04/17 01:52 PM
08/04/17 01:52 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Is the the super stealth version?
Re: 440 source heads [Re: Prochargedmopar] #2348513
08/04/17 03:13 PM
08/04/17 03:13 PM
BradH Offline
BradH  Offline
Uhhhh... whomever owns that flow bench needs to get a set of PTS calibration plates (http://www.flowbenchtech.com/orificeplates.html) and/or some stiffer springs to keep the valves at the specified height when flowing heads. Those low-lift #s are in the Twilight Zone.
I know flow bench #s can't be compared DIRECTLY, but when they're using a common calibration standard you can expect they're going to be REASONABLY close.
Larry Smith's posted #s:
.100" - 120
.200" - 177
.300" - 239
MCH's CNC Stealth program advertised #:
.100" - 75.0
.200" - 156.7
.300" - 219.8
The high-lift #s might be perfectly comparable. However, when I see that the low-lift #s are so far off from "normal", I feel the need say something 'cuz it brings the credibility of the whole flow test into question.
Don't shoot the messenger! It is what it is...
Re: 440 source heads [Re: BradH] #2348518
08/04/17 03:26 PM
08/04/17 03:26 PM
PA.
"Little"John
"Little"John
PA.
Kinda why if I don't see before and after numbers I keep moving on. Same bench before and after and you compare to what you see on your bench. It takes me less than 5 minutes to check intake and exhaust calibration and I do so before every different head goes on my bench. And I'm not even selling anything, I just want to know for myself. LOL
1970 Duster
5.984@112.52
5.982@112.56 mph
9.38@138.67
