511 project #2343813
07/26/17 06:30 PM
07/26/17 06:30 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Been using all my free time lately to get this project finished. Just waiting on a radiator to get here and finding the correct hoses.
Re: 511 project [Re: mopar dave] #2343815
07/26/17 06:33 PM
07/26/17 06:33 PM
Mt Morris Michigan
Mt Morris Michigan
Tomorrow i'll get the plug wires run and hooked to coil. Ordered the engineered cooling products radiator in a 26" core and a shroud from summit. Shouldn't be too much longer.
Re: 511 project [Re: mopar dave] #2343833
07/26/17 06:49 PM
07/26/17 06:49 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Bend a piece of wire or coathanger to form the bends you need. Take it to the parts store and ask if you can look through their hose inventory. If I recall, my upper was a Ford Ranger part #.
'63 Dodge 330
11.19 @ 121 mph
Re: 511 project [Re: GY3] #2343859
07/26/17 07:38 PM
07/26/17 07:38 PM
Mt Morris Michigan
Mt Morris Michigan
Good idea. Thanks
Re: 511 project [Re: GY3] #2343983
07/26/17 11:24 PM
07/26/17 11:24 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
thats the way I do it also.
Re: 511 project [Re: mopar dave] #2344092
07/27/17 07:41 AM
07/27/17 07:41 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I sectioned the chassis rails and fitted a 32" rad.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: 511 project [Re: mopar dave] #2344110
07/27/17 09:27 AM
07/27/17 09:27 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Looking good!I bet this gives you the itch to drive it also.Will you run the plug wires under the pipes?I used some 2 piece wire separators from the auto parts store.
Re: 511 project [Re: mopar dave] #2344134
07/27/17 10:26 AM
07/27/17 10:26 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I think my crossflow on my 517 used a top hose from a 5.0 Lincoln Mark 7 if I remember right.
Might want to re-think the flex fan and go to electric pullers. Rigid/semi-flex fans are big HP killers. In fact Dulcich and Fryberger did an informative EngineMasters episode on it on youtube.
WIZE
In Car:
Re: 511 project [Re: deaks] #2344180
07/27/17 11:18 AM
07/27/17 11:18 AM
Mt Morris Michigan
Mt Morris Michigan
I'm gonna have to do a little cutting to get the 26" in there. shouldn't be too bad. Using a shroud with this as well.
Re: 511 project [Re: Clanton] #2344182
07/27/17 11:19 AM
07/27/17 11:19 AM
Mt Morris Michigan
Mt Morris Michigan
yeah, the wires run under the headers. Gonna work on those today.
Re: 511 project [Re: Streetwize] #2344186
07/27/17 11:22 AM
07/27/17 11:22 AM
Mt Morris Michigan
Mt Morris Michigan
Gonna take this in steps. Oil cooler then electric fans then new 2 row 1.5"/ row radiator if needed. More than likely i will spend the rest of the summer figuring everything out.
Re: 511 project [Re: mopar dave] #2344273
07/27/17 01:01 PM
07/27/17 01:01 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
You may have to make a tab that holds the wires against the engine and have the header bolt hold it.The good thing is you have aluminum heads with a sealed header bolt hole.
Re: 511 project [Re: Clanton] #2344527
07/27/17 10:15 PM
07/27/17 10:15 PM
Mt Morris Michigan
Mt Morris Michigan
All went well with the plug wires under headers. Had to wire tie them back away from headers. Plugs are easy to change on dr side, but pass side is a bit difficult.
Re: 511 project [Re: mopar dave] #2344575
07/27/17 11:39 PM
07/27/17 11:39 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Did you put an engine plate in the rear also ?
Headers are the Maddogs or TTI ?
Dan
Re: 511 project [Re: Wedgeman] #2344595
07/28/17 12:05 AM
07/28/17 12:05 AM
Mt Morris Michigan
Mt Morris Michigan
front plate only. Mad dog headers for lo deck.
Re: 511 project [Re: mopar dave] #2344658
07/28/17 02:01 AM
07/28/17 02:01 AM
W
Wedgeman Offline
Wedgeman  Offline
W
Where did you get the front plate ?
Dan
Re: 511 project [Re: Wedgeman] #2344818
07/28/17 01:29 PM
07/28/17 01:29 PM
Mt Morris Michigan
Mt Morris Michigan
Hughes engines. AR plate.
Re: 511 project [Re: mopar dave] #2344826
07/28/17 02:13 PM
07/28/17 02:13 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Will removing the valve covers help you reach the plugs on the ps?This helps with getting to mine.
Re: 511 project [Re: Clanton] #2344830
07/28/17 02:18 PM
07/28/17 02:18 PM
Mt Morris Michigan
Mt Morris Michigan
Not really. I have to remove the pressure regulator from the inner fender, than i can reach up under the #2 tube to get them. Not bad, but more effort involved than with the dr side.
Re: 511 project [Re: mopar dave] #2345500
07/30/17 12:03 AM
07/30/17 12:03 AM
Mt Morris Michigan
Mt Morris Michigan
Egineered cooling products Radiator is in. Surprised how well the summit shroud fit radiator and fan. Think this will cool?
