Page 6 of 9 1 2 3 4 5 6 7 8 9
Re: Weird MoPar interchangability..... [Re: Pacnorthcuda] #23434
12/05/09 12:53 PM
12/05/09 12:53 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
When I had my 1934 Dodge, 60s-up Mopar steel wheels fit perfectly. A 1965 B-body rear also fit nicely inside the fenders with just a perch move.
Re: Weird MoPar interchangability..... [Re: Pacnorthcuda] #23435
12/05/09 01:11 PM
12/05/09 01:11 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
The speed-warning device in the passenger seat of a 70 'Cuda telling the driver to slow down can be installed in other cars with the exact same functionality.
didn't know about that option exist
Re: Weird MoPar interchangability..... [Re: NachoRT74] #23436
12/05/09 01:31 PM
12/05/09 01:31 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
You're obviously not married....
Re: Weird MoPar interchangability..... [Re: GoodysGotaCuda] #23437
12/05/09 01:46 PM
12/05/09 01:46 PM
bc canada
dbailey43 Offline
dbailey43  Offline
bc canada
don't know if this is common knowledge,but '67 4 piston calibers,are used on mustang 2's up here and a whole lot cheaper than my mopar parts guy!
Re: Weird MoPar interchangability..... [Re: Commando1] #23438
12/05/09 02:43 PM
12/05/09 02:43 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
LOL... not, and not even living in USA. beside that E bodies weren't assemblied down here. How is coded on tag/buildsheet ?
Re: Weird MoPar interchangability..... [Re: NachoRT74] #23439
12/05/09 06:59 PM
12/05/09 06:59 PM
South Carolina
FM3_1970 Offline
FM3_1970  Offline
South Carolina
That would be MRS. For export to Latin America, SRA.
Re: Weird MoPar interchangability..... [Re: FM3_1970] #23440
12/05/09 11:20 PM
12/05/09 11:20 PM
wisconsin
swifter Offline
swifter  Offline
wisconsin
Here is a good one and when you think about it someone knew we were going to do this--A 70 A833 with smallblock bell housing will bolt right up to a 2006 5.7 Hemi and will go right in to a 70 Duster--Just finished this & It still freaks me out that this was a NO-SWEAT install--Swifter
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: Weird MoPar interchangability..... [Re: CrAzYMoPaRGuY] #23441
12/05/09 11:45 PM
12/05/09 11:45 PM
Hiram, Georgia
474218 Offline
474218  Offline
Hiram, Georgia
The latch hardware for 68-70 B-body coupe popout rear windows is the same as that used on the 70-75 A-bodies with popout rear windows.
Re: Weird MoPar interchangability..... [Re: Greg55_99] #23442
12/06/09 01:18 AM
12/06/09 01:18 AM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
Ummm.... Bellhousing from 96-00 2.5L Dakota fits Chevrolet LS4....
Ok, I'm done...
Greg
I'm not suprised considering GM has manufactured a lot of transmissions for Chrysler.
Re: Weird MoPar interchangability..... [Re: swifter] #23443
12/06/09 06:59 AM
12/06/09 06:59 AM
NE Ohio
ixelerate Offline
Go Buckeyes!
ixelerate  Offline
Go Buckeyes!
NE Ohio
good tech to know! did I miss a thread about the install?
[img][/img][img]http://i277.photobucket.com/albums/kk45/ixelerate/random/falcon.gif[/img]
Re: Weird MoPar interchangability..... [Re: GoodysGotaCuda] #23444
12/06/09 09:56 AM
12/06/09 09:56 AM
ill
dennismopar73 Offline
ill
front end off my 70 dart will bolt
on my 75 duster perfect fit
so does the pass and drivers doors
now i can have wing windows on my duster??
Re: Weird MoPar interchangability..... [Re: dennismopar73] #23445
12/06/09 10:28 AM
12/06/09 10:28 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I think the doors will not match the dusters pillars....
Re: Weird MoPar interchangability..... [Re: buildanother] #23446
12/06/09 08:21 PM
12/06/09 08:21 PM
ill
ill
yes they do
perfectly as a matter of fact!!!
just gives you a wing window!!
Re: Weird MoPar interchangability..... [Re: ixelerate] #23447
12/06/09 08:24 PM
12/06/09 08:24 PM
ill
ill
75 ford ltd trunk lock
will work in a 67 dodge coronet trunk lock
Re: Weird MoPar interchangability..... [Re: dennismopar73] #23448
12/06/09 08:26 PM
12/06/09 08:26 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
yes they do
I looked at them and thought the windshield was at a different angle.
Re: Weird MoPar interchangability..... [Re: Rug_Trucker] #23449
12/06/09 08:51 PM
12/06/09 08:51 PM
chicagoland,usa
chicagoland,usa
Not sure how it will be in the water leak department.....
Re: Weird MoPar interchangability..... [Re: buildanother] #23450
12/06/09 09:17 PM
12/06/09 09:17 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
.040 over 360 file fit piston rings are the same as standard 340 rings only a LOT cheaper.
Re: Weird MoPar interchangability..... [Re: JonC] #23451
12/06/09 09:35 PM
12/06/09 09:35 PM
Rug_Trucker Offline
Rug_Trucker  Offline
I have non file fit 350 Chevy rings in my .040 360.
Re: Weird MoPar interchangability..... [Re: Rug_Trucker] #23452
12/06/09 09:52 PM
12/06/09 09:52 PM
Frozen Wastelands, Ontario, Ca...
Dr Lebaron Offline
Dr Lebaron  Offline
When I need rear drums on a FMJ, I order 89 Crown Vics.
They are nicer than the Chrysler replacements.
Re: Weird MoPar interchangability..... [Re: Mopar1] #23453
12/06/09 10:01 PM
12/06/09 10:01 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
Such as?
I figure it's the other way around... New Process(Chrysler) made transfer cases for all the big 3 and then some, there was also a version of the OD 833 in Chevies known as the MY6.
