Disconnecting Ammeter (precautionary) #2343887
07/26/17 08:54 PM
07/26/17 08:54 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
I've been advised to "bypass" the Ammeter in my newly purchased '79 Power Wagon as they are a fire hazard, or at least melt the dash hazard. I do recall hearing this before, I believe possibly on other Mopars. I'd really like to still have the gauge in the pod for looks. I have not opened up the dash yet, but am about to as I have purchased NOS gauges to replace faded ones and the typical broken speedometer needle. I want to do everything at once while I have dash apart, and I am wondering if there's a wire or two I can snip on the Ammeter behind face plate, and still have it plugged into the pod for the sake of looks?
Thanks.
Facts are stubborn things.
Re: Disconnecting Ammeter (precautionary) [Re: larrymopar360] #2343896
07/26/17 09:03 PM
07/26/17 09:03 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Just put both the red and black wires under the same post of the meter. Bypasses the meter and maintains a closed circuit. No cutting, no splicing, no problems.
Might want to add a voltmeter on the bottom of the dash or someplace. Can tap off of the same post of the ammeter that the two wires are on for the hot lead to the voltmeter. Then just ground the other voltmeter lead.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Disconnecting Ammeter (precautionary) [Re: larrymopar360] #2343951
07/26/17 10:20 PM
07/26/17 10:20 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Thank you moparmarks. I was thinking of adding voltmeter in a semi-discrete place (I like the clean stock look) so I will do as you advise with wire.
Thanks again for valuable information.
Larry
Re: Disconnecting Ammeter (precautionary) [Re: larrymopar360] #2344027
07/27/17 12:59 AM
07/27/17 12:59 AM
moparmarks Offline
moparmarks  Offline
No problem.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Disconnecting Ammeter (precautionary) [Re: larrymopar360] #2344061
07/27/17 02:27 AM
07/27/17 02:27 AM
It's beer:30 somewhere
adventurer Offline
adventurer  Offline
Larry
For a stock look add the factory voltage and vacuum gauge to the left side of your dash. There is set on eBay right now (not mine) a bit pricey if you look around at swap meets you will find a deal on a set of gauges. twocents
77 Dodge Adventurer SE 440 2wd SWB
78 Dodge Adventurer SE 440 2wd Utiline
90 Dodge D150 SWB 2wd 318fi 4speed
60 Desoto Adventurer 2dr
67 Dodge Dart Gt Conv. 273 4bbl
04 PT Cruiser GT Turbo
14 Ram R/T
"Life's to short to drink cheap beer."
Re: Disconnecting Ammeter (precautionary) [Re: larrymopar360] #2344359
07/27/17 03:01 PM
07/27/17 03:01 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I opwend a lot of them I disconnected the amp gauge on all of them.Then used a volt meter.Just as said disconnect the battery.Pull the gaue palen for it and disconnect the wires.I just used a screw and nut then taped the heck ouy ot them and put it all back.Never a problem You can also put both on one side of the gauge.Rocky
Chrysler Firepower
Re: Disconnecting Ammeter (precautionary) [Re: therocks] #2345273
07/29/17 02:02 PM
07/29/17 02:02 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
You want stock, you got stock.
I see no reason to by pass that gauge.
Just make sure your connections are clean and solid.
Don't forget the bulk head connections.
As long as all is well the system works fine.
Just one mans opinion.
I have mechanical Aptitude.
I can screw up anything.
Re: Disconnecting Ammeter (precautionary) [Re: larrymopar360] #2345319
07/29/17 04:09 PM
07/29/17 04:09 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Adventurer I will check out ebay, thanks. I've only looked at NOS Ammeter for the new unfaded needle.
therocks; thanks for your info.
bboogieart: I've just heard of too many melted housings on these trucks. It worries me to leave it connected, even with clean connections. I don't think the stock Ammeter really does me much good anyhow. Every old Mopar I've had that had an issue, I noticed dimming headlights or dash lights before the Ammeter gave me a warning. I do thank you for your opinion though.
Re: Disconnecting Ammeter (precautionary) [Re: larrymopar360] #2347156
08/02/17 08:21 AM
08/02/17 08:21 AM
adventurer Offline
adventurer  Offline
There is a volts and vacuum gauge pod for sale in the truck parts section on this site (not mine), Just thought I would point it out to you so you could see what one looks like. The bezels were also made in wood grain finish also in case that is how your dash is.
14 Ram R/T
Re: Disconnecting Ammeter (precautionary) [Re: adventurer] #2347493
08/02/17 09:43 PM
08/02/17 09:43 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I checked it out. Nice. Mine is not woodgrain. Thanks for pointing it out for me to check out.
Re: Disconnecting Ammeter (precautionary) [Re: larrymopar360] #2347504
08/02/17 10:08 PM
08/02/17 10:08 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Here's mine. Still haven't had a chance to replace broken speedometer and other gauges with the NOS ones I have, and bypass ammeter.
Re: Disconnecting Ammeter (precautionary) [Re: moparmarks] #2357124
08/20/17 02:22 PM
08/20/17 02:22 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Got side-tracked with engine stuff, so just getting around to this. Here's a NOS one I'm looking at. I don't see any wires. Are they hidden in pic? It's the only pic of back from seller.
Re: Disconnecting Ammeter (precautionary) [Re: larrymopar360] #2357195
08/20/17 05:50 PM
08/20/17 05:50 PM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
The wires are the wiring from your truck, they connect to those posts. I have done this on several trucks, I just snip the ends and solder them together and wrap with heat shrink. Bypass it all!
Re: Disconnecting Ammeter (precautionary) [Re: 77ProStreet] #2357218
08/20/17 06:42 PM
08/20/17 06:42 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I converted mine to a volt gauge. I used a Sunpro CP7985 which fit right in the cluster. The studs were shorter than the amp gauge so I used a step drill to open up the holes and wired the 12V and ground.
Re: Disconnecting Ammeter (precautionary) [Re: larrymopar360] #2357257
08/20/17 08:14 PM
08/20/17 08:14 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
T2R9: Thank you so much for info and pics! Perfect. Looks good and I appreciate the part number too!
Larry
Re: Disconnecting Ammeter (precautionary) [Re: 77ProStreet] #2357272
08/20/17 08:54 PM
08/20/17 08:54 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Thank you. If I don't do what T2R9 did right away, I'll at least do this until I do so I don't melt anything in the mean time. I do like what he did so I'll probably do that eventually anyway. up
Larry
Re: Disconnecting Ammeter (precautionary) [Re: larrymopar360] #2357814
08/21/17 09:45 PM
08/21/17 09:45 PM
IN
ahy Offline
ahy  Offline
IN
Have you bypassed charge current through the bulkhead connector yet? That is the weakest link in the system.
Ammeter connections are a weak link but not as much as the bulkhead connector.
True story... on a '74 D200 the bulkhead connector lasted until about year 5. Then melted. Emergency bypass lasted until year 20 when the truck was retired due to frame rust. The ammeter connections lasted the life of the truck.
If the alternator and electrical loads are stock, the ammeter should be OK with thoroughly cleaned and tightened and greased connections. If you have increased loads or alternator output or both, best to bypass the ammeter also IMO.
A nice heavy wire from alternator output to the fender relay bypasses both. Fusible link 2 gauge sizes smaller than the bypass wire recommended. A voltmeter is needed with this bypass as the ammeter will not be functional.
Re: Disconnecting Ammeter (precautionary) [Re: ahy] #2358022
08/22/17 10:25 AM
08/22/17 10:25 AM
E
earlymopar Offline
earlymopar  Offline
E
Do you have pictures of your truck that uses this method? Not to hijack this thread but I think it would be helpful to others too. I'm in the process of swapping a poly 318 for the original slant 6 in my 1965 Series I and have upgraded to a mini-Denso alternator that has more amperage than my original alternator so have been planning for an upgrade to by-pass the amp gauge and bulk head connector.
Thanks, -EM
" A nice heavy wire from alternator output to the fender relay bypasses both. Fusible link 2 gauge sizes smaller than the bypass wire recommended. A voltmeter is needed with this bypass as the ammeter will not be functional"
Re: Disconnecting Ammeter (precautionary) [Re: ahy] #2358129
08/22/17 03:06 PM
08/22/17 03:06 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Very interesting information. No, I have not done anything electrical yet. Truck leaking bigtime from freeze plugs so have been concentrating on engine. If you could post pics, I also would be VERY appreciative! Thanks again.
Re: Disconnecting Ammeter (precautionary) [Re: larrymopar360] #2358290
08/22/17 08:38 PM
08/22/17 08:38 PM
IN
ahy Offline
ahy  Offline
IN
I will bring my camera home from work tommorrw and take a pic of the bypass setup described in a '70 Challenger.
