My Plan B engine for my Sport Fury is another 440 that I pulled from a '77 New Yorker about 8-10 years ago, and has been in dry storage since. Another ~100K mile engine, but 9 years newer than the one from my Fury. I'm going through checking this engine before I clean it up and install it for the remainder of the cruising season, and noticed some weird looking details on the crank.
ID pad shows Maltese cross and X:
1977_440_Engine by
clair_davis, on Flickr
Crank seems to confirm 0.010" undersized mains:
1977_440_Engine by
Additionally, there is this "R" on one of the counterweights. I can't tell if it means anything:
1977_440_Engine by
Lots of little diamonds, hearts, stars, etc. on the rod big ends rather than numbers. Interesting stuff I don't recall ever seeing before.
I'm doing a plastigage reality-check on bearing clearances, and what's striking me as unusual and maybe troubling is a strange little tab on the rod cap. Looks almost like a piece that didn't get machined fully, but as far as I can tell it's on all of the caps:
1977_440_Engine by
1977_440_Engine by
Does that just lock in to the notch on the rod, or should I be worried about this? My concern is that it might keep the cap from seating properly, but it has lasted for 100K miles so far...
Lastly, two rods on the 5-6 journal don't move side to side on the journal very easily. All the other rods will move within their side clearance with a finger push, but these two won't. A tap with a rubber mallet and they move just fine, but not by hand. Again, I don't know if this is a big deal, there is clearance between the rods and crank journal, and it's been that way for 100K miles. I can't plastigage this journal because the caps have to move around too much to remove them compared to the other caps. Everything shows 0.0015" clearance so far, so I'm going to assume this journal is in that ballpark, too.
Overall, a really solid engine so far, but I want to avoid doing any damage.
Thanks,
Clair
