Re: Firm Feel LCA sway bar tabs
[Re: BcudaChris]
#2343160
07/25/17 05:19 PM
07/25/17 05:19 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Similar to the setup Addco uses, but beefier. The Addco "bracket" is just L shaped with no reinforcements. I've run Addco bars for years.
[Re: BcudaChris]
#2343176
07/25/17 05:39 PM
07/25/17 05:39 PM
Posts: 701 Northern California
lilcuda
Northern California
FF builds quality stuff. I don't think you'll have a problem.
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
[Re: BcudaChris]
#2344121
07/27/17 10:10 AM
07/27/17 10:10 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
Are not factory LCA with sway bar provisions part of the LCA stamp?
EDIT: forget it, they are welded... my bad!
