Firm Feel LCA sway bar tabs #2342589
07/24/17 06:19 PM
07/24/17 06:19 PM
Colorado front range
BcudaChris Offline OP
Anyone use these? They look to be a bolt-in solution, which I'm not averse to if they work well. I intend to install a larger than stock bar. Easier than hunting down a LH LCA.
Problems? Concerns?
Re: Firm Feel LCA sway bar tabs [Re: BcudaChris] #2342668
07/24/17 08:35 PM
07/24/17 08:35 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I'd like to see what they look like.
Re: Firm Feel LCA sway bar tabs [Re: Kern Dog] #2343108
07/25/17 03:45 PM
07/25/17 03:45 PM
Best I can find, unfortunately.
Re: Firm Feel LCA sway bar tabs [Re: BcudaChris] #2343160
07/25/17 05:19 PM
07/25/17 05:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Similar to the setup Addco uses, but beefier. The Addco "bracket" is just L shaped with no reinforcements. I've run Addco bars for years.
Don't be the exception.
Re: Firm Feel LCA sway bar tabs [Re: BcudaChris] #2343176
07/25/17 05:39 PM
07/25/17 05:39 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
FF builds quality stuff. I don't think you'll have a problem.
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: Firm Feel LCA sway bar tabs [Re: BcudaChris] #2343202
07/25/17 06:29 PM
07/25/17 06:29 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Ditto on Supercuda and lilcuda's assessments.
Re: Firm Feel LCA sway bar tabs [Re: BcudaChris] #2343254
07/25/17 08:44 PM
07/25/17 08:44 PM
Jamey Offline
Jamey  Offline
You could weld them on instead of bolting on.
Re: Firm Feel LCA sway bar tabs [Re: BcudaChris] #2343867
07/26/17 07:55 PM
07/26/17 07:55 PM
Thanks guys, as I expected to hear regarding FF.
I could definitely weld them, but am looking for some 1st hand experience from someone who has done a home bole in install and flogged them.
I'm going with a stock sway bar (for now) but want to be sure it'll hold up to a big fat one later on with the bolt in config. Otherwise, will weld.
Re: Firm Feel LCA sway bar tabs [Re: BcudaChris] #2343966
07/26/17 10:50 PM
07/26/17 10:50 PM
Jamey Offline
Jamey  Offline
I have a helwig sway bar on my car with the bolt on tabs. I'm going to weld mine on. They do pivot on the bolt. Not sure if it makes a difference or not but the factory welded them, so I will too.
Re: Firm Feel LCA sway bar tabs [Re: BcudaChris] #2344121
07/27/17 10:10 AM
07/27/17 10:10 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Are not factory LCA with sway bar provisions part of the LCA stamp?
EDIT: forget it, they are welded... my bad!
